Lightning+ Well= No Water Need Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2009, 06:25 PM   #1
Florida Cracker
Lightning+ well= no water Need Help
Alright this sucks.
I am on a well here, and there was a lighting strike in my backyard, and now my well doesn't work.
I reset all of the breakers, including the well disconnect.
The well disconnect has those old glass fuses, and I verified power coming in before the fuses, and leaving after the fuses.
The wires then go to some little switch type thing and I have power there too. Then the wires go down in to the casing to the pump.
My pressure gauge is saying 0 psi.
I don't know what else to check, and I am worried that my pump got cooked somehow.
Jack A. Trades is offline   Reply With Quote
Old 06-10-2009, 06:33 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Measure the voltage between the two fuses. Should be 240 vac.
If you have voltage then you may have smoked the pump. Another thing to check is if there is a control box in the well then the capacitor(s) may have taken the brunt of the spike. If you cannot find any capacitors then more than likey the pump is smoked.
Old 06-10-2009, 06:36 PM   #3
not much help but my brother in laws pump got smoked from lightning, and his pump was down 125'
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 06-11-2009, 08:34 AM   #4
Rewards Points: 150
My well got hit by lightning also. It blew the capacitor in it. Git it replaced and have them install a lightning protector or surge protector on your system. There is also a chance that your well pump was fried also.
al's sewer is offline   Reply With Quote
Old 06-11-2009, 01:39 PM   #5
Water quality'n pump guy
You need to troubleshoot the pump motor and power cable before you do anything like a new pump!!
All you need is an amp/ohm meter and instructions, and some common sense to work with 240vac.
http://www.franklin-electric.com/bus...M/page-43.aspx
Gary Slusser is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
