Old 10-12-2009, 12:07 PM   #1
Toe
Question
Lever faucet loose; poor flow
Hi.
I have a bathroom lever faucet on which the lever has started functioning poorly.
It is a little wobbly and the flow is very reduced (an identical faucet next to it works fine). It is about 2-3 years old.
Can someone tell me what to do to identify the source of the problem? Everything I find online is about leaking faucets, and this does not leak. It is just not flowing well.
Thanks.
Toe is offline   Reply With Quote
Old 10-12-2009, 02:39 PM   #2
Household Handyman
IF you are talking about a "single lever" unit, and I bet you are: Some of these units are notorious for having internal parts come loose just enough to let the cartridge rotate to cause this problem. I'm betting it's a Moen . It's really a simple fix: you remove the handle, there is a way, different models have different methods so I cannot tell you how yours is. After removing the handle you will probaly find a type of screw-on ring on top of the cartridge that must align with the cartridge to seat the cartridge properly. These rings usually have two or four slots in them for a special tool to use, I very carefully use the end of a screwdriver and tap the end of the screwdriver to loosen it or tighten it. It's not a part of an bulldozer, so it doesn't have to be extremly tight. Without a model number or picture, that's about the best I can do, I hope this helps. IF you know the manufacturer and/or model number you may be able to Google it for an installation manual which will have this information pertaining to your specific unit. Good Luck, David
Old 10-12-2009, 03:44 PM   #3
Toe
Yes, it is a single-lever, and it is a Delta. And, ahem, the problem turned out to be much simpler than I was making it out to be.
In fact, it was two separate problems. The screw holding the lever was a little loose, resulting in the loose feel of the lever. The reduced flow was simply a clogged screen.
Tightening the screw and cleaning the screen fixed it up right good.
Another "Kitchen faucet replacement" thread! :) emperor_black Plumbing 3 07-27-2009 11:44 PM
Loose / Bent Faucet yasman Plumbing 1 03-30-2009 09:50 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 02:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Faucet Drain Lever Installation DK75 Plumbing 3 05-21-2008 11:08 AM
