-   -   level or not level toilet? (http://www.diychatroom.com/f7/level-not-level-toilet-55952/)
ron0805 10-26-2009 12:54 AM
Im going to install my new toilet,and i put it over the flange to see how it looks.The problem im having is that its not level.When i leveled it from front to back it was about 3/8 off.At the back of the toilet its higher than the front, so the gap would be at the front.My question is do i put the toilet completly on the floor but be off level or do i get it level or close to level and caulk around the gap at the bottom?
Thx
buletbob 10-26-2009 06:02 AM
Mix some plaster of pairs and put on the floor under where the bowl is going to be installed. set the toilet down in place and level the toilet on the wet plaster. I push the bowl down into the plaster and wax seal until level and then snug up the hold down nuts. and I then wipe up the excess plaster.
majakdragon 10-26-2009 11:40 AM
Use plastic toilet shims to level the toilet. You can then use caulking or grout to seal around the base to hide the gap. I recommend not sealing the very back of the bowl, so if there is a leak it will show and not let water sit under the toilet and rot the subfloor.
ron0805 10-26-2009 02:10 PM
thx ill do that
AllanJ 10-26-2009 05:16 PM
I suggest having the toilet supporting means (plaster, shims, etc.) hard and in place and tested first then take off the toilet, put in the wax seal, and do the final installation.
Putting in the wax ring while the plaster is still wet is risky because as you rock the toilet back and forth to get the plaster leveled just right, you may deform the wax too much and break the seal.
If you don't level the toilet at all then it might not flush properly.
