Lesson Learned... - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2011, 07:02 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Lesson learned...
Okay, I had this theory (I know it's kind of like hold my beer I'm going to try sumthin).
In my house the laundry room is on the back side of a bedroom wall. The drain runs thru the shared wall. If you run a load of wash at bedtime, when the washer drains it will wake you up. So I figured 'I know' I will extend the drain hose deep into the pipe and it will stop a lot of the noise of water hitting the PVC. WRONG..... since the additional hose reached deep into the pipe it sat up a siphon action. When you ran a load of wash the drain would pull water out of the tub as fast as it added.
MikeKy55 is offline   Reply With Quote
Old 01-05-2011, 07:22 PM   #2
get it repiped in cast iron. very quiet and will last for years
the_man is offline   Reply With Quote
Old 01-06-2011, 03:46 AM   #3
Homerepairguy's Avatar
Rewards Points: 998
Doesn't the sound of the washer running keep you up, never mind the draining?
Homerepairguy is offline   Reply With Quote
Old 01-06-2011, 06:27 AM   #4
Rewards Points: 1,216
Sounds like the easiest way to handle this is to wash at other hours. It's a lot cheaper than cast iron installation.
COLDIRON is offline   Reply With Quote
Old 01-06-2011, 07:59 AM   #5
MikeKy55's Avatar
Rewards Points: 254
Homerepairguy: it really doesn't make enough noise otherwise.
Coldiron: Thats exactly what I will do. No washing late at night.
Lessons Learned gdoucette Drywall & Plaster 7 07-05-2010 04:19 PM
Lesson Learned Eric_ht Painting 3 03-05-2010 07:29 PM
A relief off of my shoulders and lessons learned Holt Safety 1 09-25-2009 05:12 PM
A lesson learned - don't make my mistake and a pvc drain question edwood79 Plumbing 0 11-20-2008 10:09 PM
UGH! A lesson for new Pre-Hung Doors javan General DIY Discussions 6 08-08-2008 07:47 PM
