Lengthen Sewer Cleanouts? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2010, 05:32 PM   #1
Rewards Points: 29
My cleanouts are just at ground level, in an area that I need to build up to improve drainage away from the foundation.
I don't want them to be buried and hard to find later.
My plan is to lengthen them a little (6-10") with some ABS splices and whatnot. Any reason I should not do this?
Genhawk21 is offline   Reply With Quote
Old 11-23-2010, 06:30 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Nope,... You'd be Crazy not too...
The Following User Says Thank You to Bondo For This Useful Post:
Genhawk21 (11-23-2010)
Old 11-23-2010, 09:35 PM   #3
I wouldn't use abs because of how weak of a pipe it is. use PVC or preferably the green pipe
immeraufdemhund is offline   Reply With Quote
The Following User Says Thank You to immeraufdemhund For This Useful Post:
Old 11-23-2010, 09:52 PM   #4
Rewards Points: 29
Thanks folks!
Sewer Pump: How to make do? austinbirdman Plumbing 2 05-04-2011 09:35 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
