Legal ABS Connection? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2013, 12:33 PM   #1
Rewards Points: 866
Is this connection legal? [After asking I scratched the fitting the mechanical is used to connect with and it is definitely CI so I guess this is legal. Correct me if I am wrong.] It is located in the joist tunnel between the 1st and second floors of my house.
Two lines run to that 90. A 3" soil line and a 2" line that I believe vents. It looks like just beneath the chipboard there is antoher fitting that waste lines "T" into.
My concern is whether or not that steel clamp would be a mechanical connector similar to a very large Fernco and if it is would it be legal to connect ABS to ABS [Turns out it is ABS to CI].
Even if it may not be up to current code, this was built 24 years ago and I don't know that I would want to mess with it if it has been fine all that long and the connection looks good.
Legal ABS Connection?-soil-stack-001.jpg   Legal ABS Connection?-soil-stack-003.jpg   Legal ABS Connection?-stack-001.jpg
Klawman is offline   Reply With Quote
Old 12-12-2013, 06:34 PM   #2
Rewards Points: 1,700
Looks like some form of transitional coupling.
The Following User Says Thank You to Ghostmaker For This Useful Post:
plummen (12-12-2013)
Old 12-12-2013, 06:47 PM   #3
Rewards Points: 866
Yep. It couples ABS in the joist tunnel between floors CI dropping down in what looks to be a wall.
Old 12-12-2013, 07:06 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Replace the metal plumbers strap with the plastic version.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 12-12-2013, 07:59 PM   #5
Rewards Points: 582
its called a mission cuppling....I think..... well i say that because iam getting forgetful...ha ha ha ..ben sr
Old 12-12-2013, 08:15 PM   #6
plummen's Avatar
Yep ,thats a mission coupling.
The metal plumbers strap can eventually cut through plastic pipe and should be changed to plastic if its accessable.
The Following User Says Thank You to plummen For This Useful Post:
Klawman (12-12-2013)
Old 12-12-2013, 08:59 PM   #7
Rewards Points: 866
I saw a roll of that plastic strap and thought the metal would be better, but can do the plastic easily enough.
Although the mission is legal (I found another one to connect a tub waste line to a CP stack pipe on the other side of the house), does the connection look as though the ABS may have back out about a half inch or more. Perhaps it was lifted up by an up and down earthquake or perhaps the installer found it easier to loosen the mission and lift the T up in order to raise the riser for the toiler flange. To lazy to simply cut a new riser.
If I so adjust the mission, should I replace it given that the rubber sleeve is 24 years old?
Old 12-14-2013, 03:50 AM   #8
Steel plumber's tape on ABS pipe = no
Use this instead...
idlplumbLA is offline   Reply With Quote
The Following User Says Thank You to idlplumbLA For This Useful Post:
plummen (12-14-2013)
Low Hot water pressure after replacing laundry hose connection jp_jacobson Plumbing 4 05-03-2011 08:30 AM
Flexible connection required for propane heater ? SteveB2175 Plumbing 8 04-07-2011 05:22 PM
Leaking Trap Connection bklusa1 Plumbing 3 02-17-2011 10:50 AM
vent hood electrical connection question cbendock Electrical 4 02-12-2011 11:33 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 07:10 AM
