Leaky Water Valve Prior To Water Meter - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-06-2012, 11:14 AM   #1
Leaky water valve prior to water meter
How do I evacuate water inside pipe so that new valve can be soldered?
John Stephan is offline   Reply With Quote
Old 09-06-2012, 03:03 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,058
Ayuh,.... Use a compression fitting, 'n there's no need too...
Bondo is online now   Reply With Quote
Old 09-06-2012, 03:20 PM   #3
Rewards Points: 80
If you have not yet done so, you may want to contact your local utility, and ask who is responsible for that valve. I am not a plumber by trade, nor have I ever had municipal water, but am quite certain that the responsibility for that valve sometimes lies with them.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Turning valve at water meter KCnorthernCA Plumbing 15 10-22-2006 11:35 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
