Old 03-02-2007, 02:23 AM   #1
Leaky Water Sound 24/7, need your advice.
I am posting this about a friend's home.
He has a row house with a bathroom on the 2nd floor. He can hear a click/leaky water noise(like a popping sound) every few seconds and all the time. When he turns on the sink fawcet or tub fawcet he can hear a fast click/leaky water noise for 30 seconds and then it stops. When he turns off the fawcet, he can hear the click/leaky water noise every few seconds. When he's in the 2nd floor bathroom he can hear the sound inside the walls, and when he's in the next room he can hear the sound under the floor. He hired a handyman to come check it out. under the 2nd floor bathroom, there's a kitchen. He opened the ceiling in the 1st floor and saw the pipes without any leak. Tho this area was not directly under the sink/tub of the 2nd floor bathroom. It was about two feet to the right but he did see the toliet pipes and the main hot and cold pipes, he stuck a metal wire with some towel and moved it upwards and found no wetness. He couldn't find any leak, so he turned off the main water supply. The click/leaky water noise stopped. What should he do? Hire the handyman or licensed plumber to open the sink and tub fawcets and look into the pipes in the wall? that would require to break the wall. There is no water leaking from the ceiling on the first floor, althought there is an kitchen vent with under the sink/tube. Any suggestions from you experts on here? thank you.
Also, Let's say there is a leak, since it's sounds like it's a drop of water every few seconds and then rapid drops of water for 30seconds when the sink is turned on. Over the long term, will this cause any structural damage to the wood beams?
Also, when the handyman opened the ceiling he saw a unused old light color pipe hanging loosey next to the copper water pipe. When he turns off the tub fawcet fast, he hears a clap sound. It sounds like the copper pipe hits the old unused pipe. is this dangerous? Also, he felt a wind draft moving upward. Is this normal? clue
clue89 is offline   Reply With Quote
Old 03-02-2007, 08:36 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
What he is hearing is expansion and contraction of the hot water pipe, what is happening is, a pipe is sercured tight to a stud in wall, as water heats up the pipe expands, when the pipe can't move freely, it gets in a bind, this making that sound. To fix it find the loudest spot, open wall and free the pipe enough so it can expand and contract.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water Softener, need some good advice. wla6518 Plumbing 11 07-07-2011 10:09 AM
Water sound in Pipes Robb Plumbing 14 12-26-2006 11:48 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
