Leaky Waste Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2009, 04:16 PM   #1
leaky waste pipe
I found a puddle of water in my crawl space and it's coming from my PVC waste pipe. The leak occurs about 8-10 inches from the base of the vertical pipe, where it connects to the 90* elbow. Any ideas on how to stop the leak? I tried plumber's putty but that hasn't done anything.
chuckgormley is offline   Reply With Quote
Old 02-02-2009, 05:33 PM   #2
An extremely easy fix with 2 couplings and a new 90, its definetly a DIY task and shouldn't cost you more then $15, and you might be able to find some scrap pipe at a construction site, you should't need more than 1' of pipe, just cut about 6" above the 90 and 6" after the 90, glue the coupling on each ends of the pipe, take some measurments with the 90 in hand cut the pieces you need and you should have enough play in the horizontal piping to push the 90 on to the vertical.
zosoplumber is offline   Reply With Quote
Waste Pipe Replacement Handymom2008 Plumbing 5 11-24-2008 10:49 AM
Toilet Bowl to Horizontal Waste pipe BOBC Plumbing 3 08-30-2008 01:17 PM
waste pipe leveling issue amakarevic Plumbing 9 03-27-2008 05:12 PM
Raising shower waste pipe heathergeorge Plumbing 7 10-08-2007 11:06 AM
Waste pipe odor in garage? Kirsten Plumbing 3 11-21-2006 12:07 PM
