Leaky Washing Machine Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2012, 06:09 PM   #16
Rewards Points: 582
Originally Posted by sweetwaters View Post
I snaked my line tonight a when I pulled the snake out there was a lot of this black sludge stuff on the snake line. Anyone know what this might be? When I was putting the snake in the drain it got so far and then I had to use force to push the snake further down the drain line. It doesn't smell like sewage. Has an oil like consistancy. No idea what this could be.
if it been working for 5 yrs like plummen said don't reinvent the wheel..snake out drain good use proper glue and go on to another project
Old 02-04-2012, 07:22 PM   #17
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Probably just old dissolved crud in the line,Try and run water down the line or another line tying into it while you snake it to wash the crud down the drain
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (02-04-2012)
Old 02-14-2012, 08:50 AM   #18
I had this same problem. Snaked the drain, pulled out the black swamp-smelling crud. Oddly enough it made me sick for a few days (cold-like symptoms).
So like a dummy, I put a "lint trap" wire mesh thing on the end of the washer pipe. So that filled up with lint much faster than I realized. It blew off the washer hose, is God knows where in the pipe and the washer flooded again! Arrrgghhhh.
Never use a wire mesh lint trap where you can't see it every day.
Weird_T_Figure is online now   Reply With Quote
The Following User Says Thank You to Weird_T_Figure For This Useful Post:
plummen (02-14-2012)
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 05:10 PM
Unusual washing machine drain hose hook-up gnguru Plumbing 8 04-28-2011 08:40 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Washing machine in basement drain pinkertonpv Plumbing 7 05-13-2010 07:58 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
