Leaky Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2010, 07:16 AM   #1
Leaky valve
I have an old valve, which has lot of green crud on it, on a copper water pipe which was fine until I turned it and a very slow drip started but has now stopped. I am trying to decide if I should have a plumber fix it or wait. I would rather not spend the money right now. Trying to avoid water damage.
Thanks in advance for feedback.
Dennis
Densec is offline   Reply With Quote
Old 04-28-2010, 07:40 AM   #2
DIY staff
Rewards Points: 7,174
You should be able to stop the drip on a gate valve by tightening up the cap nut.--That is the nut at the top of the valve with the stem and handle sticking through it.
1/4 turn should do it. There is a flexible packing under the nut--this needs to be compressed a bit more if it's dripping.
I suggest that you take a look around the house and find all of the old gate valves and consider changing them to ball valves. Often they break --in the off position--on a Saturday night--of a holiday weekend.
Old 04-28-2010, 09:49 AM   #3
You didn't say where the drip was coming from on the valve, so I have to go with Mike and think it is the packing nut. This nut should be snugged while the valve is in the open position.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
oh'mike (04-28-2010)
Old 04-29-2010, 08:19 AM   #4
Thanks for the great feedback. At this point I am going to play it safe and have a plumber look at it.
Old 04-29-2010, 12:06 PM   #5
Densec, if the valve is leaking anywhere except the packing nut, and is soldered in, I agree with calling a Plumber. Paying $50 to $75 to have a Plumber tighten the packing nut is not a good idea. Copper/brass valves and fittings often look bad due to oxidation, but it doesn't interfere with the operation. Could also be flux that was not removed after soldering that is causing the discoloration. Good luck with whatever way you solve the problem.
Old 04-29-2010, 12:47 PM   #6
Thanks for the feedback Majakdragon. I had actually reconsidered the plumber after I posted that. It did stop leaking. I am going to take a closer look and see if tightening the packing nut is loose. I haven't worked with plumbing much and panicked a little.
I would think the plumber will recommend switching to a ball valve, which will be better, but I don't want to spend that money right now.
I agree with oh'mike that I should switch them all. But I think I will wait.
Old 04-29-2010, 12:52 PM   #7
I am sure Mike was referring to replacing when you know the old valve is bad. While ball valves are much better than gate valves, it is not economically sound to just replace a valve that is working fine.
Old 04-29-2010, 12:53 PM   #8
Agreed.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Replacing/Fixing leaky shutoff valve under sink JeffWireman Plumbing 4 02-15-2010 11:30 PM
Leaky furnace valve billinak HVAC 9 11-01-2009 08:11 PM
Leaky air valve on furnace dcam HVAC 0 11-01-2009 07:36 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
