Leaky Tub Overflow - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2009, 03:54 PM   #1
dIYHell
Rewards Points: 150
Leaky Tub overflow
My Tub overflow occasionaly leaks which the remedy is to take off the Stoper control and tighten the over flow assembly to get the gasket to seal properly against the Fiberglass tub.
Can I caluk this seal to keep this from happening? usually I determine the leak when its coming through the drywall cieling below.
rocketdoctor is offline   Reply With Quote
Old 05-04-2009, 06:46 PM   #2
Rewards Points: 156
if it comes off that much
If it comes off that much, I'd just get another one. Obviously the screws aren't holding it on.
jayp is offline   Reply With Quote
Old 05-04-2009, 07:49 PM   #3
Wethead's Avatar
Get a new gasket and then "lock tite" the screws,
Adding a tad of 100% silicone will seal her nice and good as well
Need Help With Your Pump?►WeT HeaD Pump Repair ► Watch Me On YouTube: Pump Repair TV
Wethead is offline   Reply With Quote
Old 05-04-2009, 10:30 PM   #4
Rewards Points: 1,542
Make sure you have a good gasket contact/seal on the back side.
It is not critical to have a good seal between the cap and the tub in front.
Old 05-04-2009, 11:30 PM   #5
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Dont use caulk or locktite....You'll make it a complete PIA on down the road. Get a new gasket and smear some pipe dope with teflon on it. Install the gasket then tighten it up. If the screws arent holding then it may be time for an entire new overflow assembly. If so, you'll be thanking the Almighty that no one used locktite or silicone on the damn thing.
JDC is offline   Reply With Quote
Leaky Roof arete01 Roofing/Siding 2 12-31-2008 05:52 AM
Overflow pan in attic danstar25 HVAC 13 09-16-2008 03:42 PM
Leaky wobbly shower arm tima2381 Plumbing 15 06-22-2008 04:02 PM
Bathroom floor wet; water coming _out_ of bath overflow. oceanclub Plumbing 6 01-09-2008 09:47 PM
Help with Overflow Drain Kit for Bathtub ... njchan Plumbing 1 01-08-2008 11:32 PM
