Old 10-24-2009, 01:23 PM   #1
Default Leaky tub faucet - how to get stem out
I've got a slow drip coming from the tub faucet. After reading a few DIY articles about replacing the washer in the stem or even the stem itself I started the process but I'm stuck now trying to figure out how to get the stem out of the wall I went out and bought a $20 pack of the universal shower socket valve wrench set but I don't even see where there is a hex screw. Can someone take a look at the pictures and let me know what I need to do next to get that stem out of that wall?
What vexes me most is that all the guides I've seen show a stem and hex packing nut. I see the stem but it looks recessed into the pipe with nothing to grab on to pull it out. The 2nd photo in the album shows it best.
Pictures are here: http://s922.photobucket.com/albums/ad65/chadandjody/
chadandjody is offline   Reply With Quote
Old 10-24-2009, 05:03 PM   #2
That doesn't screw out. its a moen and requires a special tool for moan cartridges.
plumber Jim is offline   Reply With Quote
Old 10-24-2009, 05:12 PM   #3
union journeymem plumber
130 plumber's Avatar
2x,you should be able to go to a hardware store and pick up a moen cartridge puller The same tool will work on all single handle moen faucets only
130 plumber is offline   Reply With Quote
Old 10-24-2009, 05:21 PM   #4
just make sure that the moen cartridge puller tool that you purchase will work with the Positemp cartridge.FYI moen sells two styles of cartridge pullers one for two handle faucet and one for a single handle faucet
Old 10-24-2009, 06:21 PM   #5
DING! DING! DING!
You all were exactly right. It didn't help I mauled the plastic tabs trying to pry it out with a screwdriver before getting the moen removal tool. It's replaced and dripping (I hope) has stopped.
More On This Topic
Hi my name is Jon on behalf of Expert Village in this video clip we will be turning on the water and inspecting our work. If you recall from the beginning of our problem we had a bathtub faucet that leaked, our first point of inspection is just to take a... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be installing our new stem. As I said before it is vital that the new stem that you bought is exactly the same as the old one, if you have a Kohler faucet your only going to be able to... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be removing our stem seat. Inside of our faucet we have here on the right our stem on the left we have our seat. Located in there our seat is sticking in there our stem comes up to our... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we'll be removing our insert. Our next step is to remove this insert here, this is what houses the o-ring that helps make that seal nice and tight. So if my initial assessment is correct once... Read More »
Hi! This John on behalf of Expert Village. In this video clip I will show you step four for fixing a leaky sillcock. If you take a look at the inner collar that we pulled off, there is a washer inside of it, and it can be a little tricky to pull out... Read More »
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 6 09-15-2009 03:17 AM
help removing faucet stem eric447167 Plumbing 10 07-02-2009 09:12 AM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 10:33 AM
Leaky Bathroom Faucet w No Markings cmcwittig Plumbing 6 12-23-2008 11:55 PM
Quick leaky faucet question JPfixit Plumbing 5 12-09-2008 01:21 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
