Old 07-03-2010, 05:09 PM   #1
Licensed Electrician
Leaky Toilet Tank Valve
So I've got a leak in my toilet tank. It's not leaking around the flapper valve (I've tried two replacements). I suspect its leaking around the base of that assembly where it attaches to the tank. It's a slow leak that slowing drains the tank into the toilet so that around every five minutes the tank fill valve opens and tops the tank back up. My problem is the toilet is a one piece affair with the toilet and tank being one casting. I can't figure out how to remove the flapper valve assembly from the tank. If I open the valve, I can see a plastic piece underneath which I assume is what the assembly is fastened to. Anyone have any idea of how to change one of these things?
Thanks in advance!
Tuckahoe Sparkplug is offline   Reply With Quote
Old 07-04-2010, 10:05 AM   #2
Raise the flapper and see if there is a screw head in the center.I had one, but it was brass, and it had a "bar" going across the opening that was tightened with the screw. If you unscrewed it, you could tilt the whole assembly and remove it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
Tuckahoe Sparkplug (07-05-2010)
Old 07-05-2010, 06:14 PM   #3
Thanks for the tip, but I think I finally figured it out. The tank was filling up nearly to the top of the overflow tube. It seems the water was syphoning out of the tank and discharging thru the fill tube that is poked down in the overflow tube. I adjusted the float to stop the fill about an inch below the top of the overflow tube and the problem seems to be resolved (at least I hope ).
Old 07-05-2010, 09:52 PM   #4
Doing it myself
Alan's Avatar
That should fix it. To be sure, make sure that the bowl primer tube isn't down INTO the overflow at all. It should just be clipped barely to the top of the overflow. This happens a lot when people change out their own fill valve, they just jam the whole thing down there because it's too long.
Journeyman Plumber
Old 07-10-2010, 07:21 AM   #5
Yep...that's what I did.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
toilet tank fills even after wall valve shut off msmitymite Plumbing 7 12-10-2009 08:56 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
