#1 |
Just call me Andrew
Leaky toilet drain
I have a toilet on the second floor bathroom that leaks down to the first floor occasionally. Usually just a few drops, but it obviously needs to be fixed. It happens when the toilet is flushed. The toilet is about 30 years old.
Here's what i have done so far. The bolts that hold the toilet to the floor were rusted and loose, allowing the toilet to rock/slide a little. I cut the bolts off, took off the toilet and replaced the wax ring with a new one (this ring also had a plastic flange attached to the underside). I then replaced the toilet and secured it to the floor with new bolts. The toilet is now very secure and does not move. I flushed it a few times, and it worked fine with no leaks, but eventually I saw water on the floor downstairs. What could it be? Could it be the flange in the floor? Crack in the toilet? If I need to buy a new toilet, I am fine with that. I just don't want to buy a new one and still have it leak. How do I pinpoint the problem? Thanks! Edit...how do I know my wax ring made a good seal? Maybe I just installed it wrong? Last edited by secutanudu; 08-17-2009 at 01:07 PM. |
| Display Modes | |
| Help me check my logic on clogged drain and overflowing toilet | Southlake_Ed | Plumbing | 10 | 01-05-2010 08:52 PM |
| Can I connect toilet drain to this drain pipe | james739 | Plumbing | 11 | 04-24-2009 08:06 AM |
| Toilet | jpark | Plumbing | 18 | 01-05-2009 08:12 AM |
| Leaky toilet flange? | ScottieBaseball | Plumbing | 5 | 01-04-2009 01:57 AM |
| Where is the toilet vent?!?!? | domgbrown | Plumbing | 4 | 01-11-2008 07:33 PM |
