Leaky Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2010, 09:34 PM   #1
Leaky Toilet
When I bought my house almost 2 years ago the inspector noticed that the vinyl was discolored around the toilet, but when he probed the floor around the base of the toilet he didn't notice any softness.
Well, as of today the discoloration has spread. And about 2 inches from the edge of the left side of the toilet is soft along the entire left side. I cut open a small spot of the vinyl around the toilet and found that the subfloor is rotted and punky but the main floor underneith is fine.
I'm planning on remodeling my bathroom within a year, should I try and do something to fix the situation now or wait until I do my remodel? Help...
mxingislife is offline   Reply With Quote
Old 11-03-2010, 10:21 PM   #2
Do something
D'Brie's Avatar
I would pull the toilet to see the extent (if any) damage that might be there. Better to be prepared, all it will cost you is a wax ring and maybe a supply line. Hope it all works out.
D'Brie is offline   Reply With Quote
Old 11-04-2010, 05:19 AM   #3
get it up and checked if it a leaking toilet then it needs looking at asap
Bobby_B is offline   Reply With Quote
Old 11-04-2010, 05:55 AM   #4
Chicago, IL
Michael Thomas's Avatar
Originally Posted by mxingislife View Post
When I bought my house almost 2 years ago the inspector noticed that the vinyl was discolored around the toilet, but when he probed the floor around the base of the toilet he didn't notice any softness.\
1) Did the inspector use a moisture meter to check for elevated moisture?
2) Did they recommend the toilet be pulled, and the source of any leaks identified and corrected?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-04-2010, 10:59 AM   #5
The inspector did not use a moisture meter, but his report did show to lift the toilet to do a further inspection.
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 06:21 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Leaky toilet flange? ScottieBaseball Plumbing 5 01-04-2009 12:57 AM
