Leaky Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2010, 12:11 PM   #1
Leaky toilet
HELP!!
I just had a toilet installed in my basement...I SET THE STOOL....it worked fine for about a month and then just started leaking! Not just a little leak but a lot! I've pulled it twice and put new rings...even put a double on but to no avail....it's still leaking. FYI the flange is agout 1/2 inch above the floor so I've had to level the stool with shims...could this be my problem?
I'd appreciate any advice!!
John <><
forHIM193 is offline   Reply With Quote
Old 02-23-2010, 03:26 PM   #2
If there is no tight seal, then it will leak. Yikes, I pity you. I replaced my toilet just a couple of months ago. Maybe your shims are too high? maybe you can get someone to hold the toilet and look underneath while seating and make sure its forming a tight seal. Are you sure the toilet is not getting rocked back and forth and hence the seal is coming off?
emperor_black is offline   Reply With Quote
Old 02-23-2010, 09:48 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
why would the flange be 1/2" above the floor? start a new thread.
Journeyman Plumber
Old 02-24-2010, 06:54 AM   #4
Need to build up floor to meet flange or lower flange closer to floor.
Good Luck.
SULTINI is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
leaky toilet debd Plumbing 3 09-22-2009 12:21 AM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Leaky toilet flange? ScottieBaseball Plumbing 5 01-04-2009 12:57 AM
Water Noise = Leaky Toilet? DIY_JC Plumbing 5 07-31-2008 06:35 PM
