Old 09-22-2009, 12:47 AM   #1
leaky toilet
Our toilet has been leaking. I could see the water running into the bowl when the toilet wasn't in use. So I replace the flap that opens and closes the water intake into the bowl, but it is still leaking into the bowl although not as much. I've run my finger over the opening and don't feel any chips. What else can I do to stop this seepage into the bowl.
debd is offline   Reply With Quote
Old 09-22-2009, 01:09 AM   #2
leaky toilet
It's the valve assembly or the float needs adjustment or is water logged. Usually the valves aren't servicable. They are pretty cheap though. Get one the right height/length.
mics_54 is offline   Reply With Quote
Old 09-22-2009, 01:10 AM   #3
leaky toilet
Maybe it's the flush valve. I have seen them get hair line cracks.
plumber Jim is offline   Reply With Quote
Old 09-22-2009, 01:21 AM   #4
leaky toilet
I'm assuming the valve assembly governs the water level. There is no float. I discovered the water level goes to the top of the vertical tube (overflow tube ?)and is actually seeping in. Since there is no float how do I adjust the water level
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 11:14 AM
Leaky toilet flange? ScottieBaseball Plumbing 5 01-04-2009 01:57 AM
Water Noise = Leaky Toilet? DIY_JC Plumbing 5 07-31-2008 07:35 PM
