#1 |
leaky spigot
my spigot is leaking right from the faucet.. I assume I need to replace washer...I closed off water...removed handle...loosened nut but cannot loosen front of spigot. I am using a wrench to hold the back of the spigot and someone else is trying to loosen with another wrench..turning counterclockwise...I DO NOT want to break anything because I am trying to save the cash. Can anyone help me out with a remedy to loosen this front part so that I can replace the washer and move on with life....thanks for your time.
sue baldino |
#2 |
Doing it myself
leaky spigot
Is it a frost free or just a standard sillcock?
If it's just a sillcock, i'd pull it off and replace it if you can't get to the bibb washer. (see below!) * Turn off water and relieve pressure. * Remove screws from siding * Cut away caulking and pull sillcock away from siding * Gently use vice grips to hold the pipe out of the siding to prevent it from disappearing when you remove the sillcock * Use two crescent wrenches to remove sillcock from threaded adapter * Teflon tape on threaded adapter * Use two crescent wrenches to thread sillcock to threaded adapter * Turn on water check for leaks * Remove vice grips * Re-caulk behind sillcock * Re-secure with screws Ta - dah
Journeyman Plumber |
#3 |
leaky spigot
thanks for the reply Alan,
this spigot is in my garage. don' know if it's standard or frost free. I doesnt look like I can get it off the pipe without removing the front first..which is the problem! I am afraid to twist it too hard and break the soldering. I have sprayed wd40 but it hasn't worked |
| Display Modes | |
| Freeze Proof garden spigot replacement | DK75 | Plumbing | 8 | 04-15-2010 08:13 AM |
| Rattling sound when spigot handle is half hot and cold? | cyfehr | Plumbing | 2 | 09-02-2009 10:28 AM |
| Hot Water Heater Spigot Leak | ellisje007 | Plumbing | 9 | 01-24-2009 08:52 AM |
| Roman Tub Spigot Problems - Phoenix Corp? | bkw | Plumbing | 1 | 10-17-2008 04:21 PM |
| Installing a Hot / Cold Water Spigot | dc2295 | Plumbing | 1 | 02-25-2008 06:10 PM |
