Leaky Solder Job-ARRRRG - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2008, 11:53 AM   #1
Rewards Points: 150
Leaky solder job-ARRRRG
I have soldered cooper pipes before without problems. Yesterday I soldered in a new gate valve with two connectors to the old pipes and the pipes into the valve. I used the bread in the pipe trick too. Today I noticed a slow dripping leak above the valve where the valve meets the pipe. I turned off the water and used the valve knob on the side to drain the pipe.
Can I just re-solder the leaky area or am I going to have to cut it all out and re-solder everything? Any tips would be appreciated. Thanks to all who respond.
Cossack is offline   Reply With Quote
Old 11-03-2008, 12:47 PM   #2
joed's Avatar
Rewards Points: 13,750
I would dry it out and try adding more solder.
Old 11-03-2008, 03:50 PM   #3
almost never works for me doing it that way but you have nothing to lose but some time. If the water prevented it from sealing the first time, most likely to do same second time, especially because you don't know if its still getting in there, but no harm, no foul, try heating it up and adding solder to it., Sometimes we just get lucky.
DUDE! is offline   Reply With Quote
Old 11-03-2008, 08:04 PM   #4
Do it right.
Heat it up and pull it apart. Clean it up with a wire brush and sand paper, reflux and re-solder it.
You probably overheated it and vaporized some of the solder. Reheating it and re-soldering it might work, then again it might not but won't show a leak for a while.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-03-2008, 11:24 PM   #5
Registered User
Termite's Avatar
Originally Posted by Marvin Gardens View Post
Do it right.
Absolutely. Adding more solder rarely works, especially long term.
Old 11-04-2008, 05:48 AM   #6
BUILDER / REMODELING CONT
buletbob's Avatar
I would have to agree. You should break it down and clean it up and re solider the joint. Drain all the water from the pipe. if your in the basement make sure you open and faucets on the first or second floor so the water will drain completely, or your just going to have a steady dribble. BOB.
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 08:59 AM
Solder for hot water heating system junkcollector Plumbing 2 09-12-2008 06:09 PM
compression fitting vs solder, block flame? nave Plumbing 9 01-24-2008 11:26 PM
solder or threaded brass valves?? fast380 Plumbing 4 01-12-2008 11:08 PM
Solder or Thread? Is one better? rgmetro Plumbing 3 04-11-2007 07:23 AM
