Leaky Shut Off Valve? [pic] - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2012, 11:56 PM   #1
Leaky shut off valve / split pipe? [pic]
Hey all! First time homeowner here. I just noticed this in the garage and was hoping to get some guidance on the problem.
Preliminary googling around suggested tightening the screw in the center of the handle an eighth of a turn or so -- which I did, but it's still leaking. Valve'll be closed in the meantime unless water is specifically needed, I guess.
The house is relatively new (<2 years old) and I'm in the Houston area, if that changes anything.
philsov is offline   Reply With Quote
Old 12-12-2012, 12:08 AM   #2
Rewards Points: 12,882
Really hard to see what it even is in that picture.
It is a PVC ball valve?
http://www.bing.com/images/search?q=...6B2E05623148B1
If so I've never seen on that can be adjusted. The screw just holds the handle on.
I'd concider opening up the wall and changing it to a brass ball valve or a Shark Bite ball valve.
To make replacement easer I'd use PVC or CPVC (what ever that pipe is) repair couplings. A repair coupling has no hub in the center of the coupling so it can be slipped over the pipe.
philsov (12-13-2012)
Old 12-12-2012, 12:22 AM   #3
sorry for the 1st pic.
Yeah, it looks like a PVC ball valve.
Is there a quicker option that doesn't involve opening up the wall? Turning off the water from the road, unscrewing this (I... can unscrew it, right?), and replacing with similar will make a short-term solution?
Old 12-12-2012, 12:31 AM   #4
That's a pex shutoff, not PVC.
Remove the screw and the handle, there may be a packing nut under the handle. Never had one leak so not 100% sure.
Only need to slighty tighten it.
The valve is not screwed on, those two crimp rings hold everything in place.
Old 12-12-2012, 12:42 AM   #5
Thanks so much for the help so far, Joe.
Turn off water before doing any of this, or will it not matter?
Old 12-12-2012, 12:45 AM   #6
No need to shut it off.
Are you 100% sure it's leaking at the stem and not someplace behind the wall?
Old 12-12-2012, 12:56 AM   #7
95%? The other side of the wall is some brick and the front, outside walkway to the house. There's a drain pattern similar to the first pic on this side too, gingerly watering the flowerbed.
It's at least this pipe. In the location of 2nd picture it's dry.
Edit: Need to sleep. Thanks for help so far. I'll post later with updates and/or further information.
Old 12-12-2012, 01:00 AM   #8
Should be able to just use a piece of toilet paper and run it around the valve.
No stain no leak.
Old 12-12-2012, 01:02 AM   #9
Need to go back and add your location to your profile.
ANy chance someone left the gargen hose hook up and the sill cock froze?
Old 12-12-2012, 01:27 AM   #10
OK. Valve is fine. Leak is still obviously present.
And... very likely regarding garden hose. We just had our first freeze last night, though I fail to see how that can cause a failure at this location.
Old 12-12-2012, 01:36 AM   #11
If there's a "freeze proof" sill cock outside and the hose is left on the pipe is unable to drain so there's water left inside it that can freeze the pipe and split it.
Old 12-12-2012, 01:44 AM   #12
Wonderful.
Given this is probably the case, next step is to locate where this split is?
Old 12-12-2012, 12:57 PM   #13
Household Handyman
Rewards Points: 1,408
O.K., so you now know that the leak is not at the valve--right? The leak is inside the wall. What we don't know is if there is a branch on the PEX leading up to the valve. IMO--you will have to remove the sheetrock below the valve box to examine the piping within the wall. Don't be surprised to find that the PEX was stubbed in before the concrete was poured and now has a pin-hole leak just as it exits the concrete. Seen this too many times. OR-there could be a branch line coming from the PEX feed line that runs to an outside sill-cock.
The Following User Says Thank You to Thurman For This Useful Post:
Old 12-12-2012, 01:51 PM   #14
Roofmaster
Rewards Points: 2,172
Screw
Ill bet somebody ran a screw through the water line installing the drywall if the valve is not definitely leaking.
Old 12-13-2012, 02:07 PM   #15
I threw in the towel and called a pro.
Removing the sheetrock from below the box showed that the water was coming UP from below. The potential for the pinhole leak was certainly present, but not the case. The flowerbed I mentioned earlier had become saturated from about 6 inches to 3 feet so it was pure water pressure/capillary action causing the water to come up from below. Given the size of the leak and damage thus far, the broken pipe occurred prior to the freezing, but the whole "unplug your hose" thing is very good knowledge for one such as myself.
Turns out there was a buried PEX connection that bent/broke said feed into the main line, probably due to a kinked angle that supposedly got fixed. That this even existed in the first place caused the plumber to have a few laughs at the expense of the builder.
Thanks everyone.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Shut off valve replacement bates Plumbing 7 12-03-2011 11:19 PM
Leaky furnace valve billinak HVAC 9 11-01-2009 08:11 PM
Leaky Shut Off Valve - Need help Rosalyn Plumbing 12 07-22-2009 08:50 PM
shut off valve behind toilet wont shut off Bunnypink Plumbing 5 04-20-2009 04:34 PM
