Leaky Showerhead After Valve Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2010, 06:03 PM   #1
Leaky showerhead after valve replacement
Hello,
I have a MOEN single handle shower valve. It was leaking (when OFF) steadily so I replaced the valve (which included new washers). The leak slowed, but still continues. What's my next step is solving this leak? Ideas?
mr.perplexed is offline   Reply With Quote
Old 01-28-2010, 06:12 PM   #2
DIY staff
Rewards Points: 7,174
Did you sand the inside of the sleeve before you installed the cartridge?
Often there is lime-rust and crud built up on the walls of the valve body--A few strokes with some fine sand paper --wipe out the crud --then install the cartridge--Hopefully the cartridge wasn't damaged by the rough surface.
Try that--Good luck--Mike--
Old 01-28-2010, 06:19 PM   #3
Well, damn. Nope, didn't know to do that. I do have a high concentration of calcium from my well. Now if I take the valve out to sand the chamber, is my new valve still good? You mentioned possible damage. What would this damage look like?
Old 01-30-2010, 04:05 PM   #4
DIY staff
Sorry it took so long to get back to you----The crud may have scratched up the rubber a bit. If it was hard to re-install(you had to really force it in) the rubber might be torn up a little.
Chances are you are fine--it may just be dripping because the rubber will not seal against the rough sides of the valve body. It doesn't take much crud to cause a drip.--MIKE---
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Leaky air valve on furnace dcam HVAC 0 11-01-2009 07:36 PM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 11:50 AM
