-   -   Leaky showerhead after valve replacement (http://www.diychatroom.com/f7/leaky-showerhead-after-valve-replacement-63046/)
mr.perplexed 01-28-2010 05:03 PM
Hello,
I have a MOEN single handle shower valve. It was leaking (when OFF) steadily so I replaced the valve (which included new washers). The leak slowed, but still continues. What's my next step is solving this leak? Ideas?
oh'mike 01-28-2010 05:12 PM
Did you sand the inside of the sleeve before you installed the cartridge?
Often there is lime-rust and crud built up on the walls of the valve body--A few strokes with some fine sand paper --wipe out the crud --then install the cartridge--Hopefully the cartridge wasn't damaged by the rough surface.
Try that--Good luck--Mike--
mr.perplexed 01-28-2010 05:19 PM
Well, damn. Nope, didn't know to do that. I do have a high concentration of calcium from my well. Now if I take the valve out to sand the chamber, is my new valve still good? You mentioned possible damage. What would this damage look like?
oh'mike 01-30-2010 03:05 PM
Sorry it took so long to get back to you----The crud may have scratched up the rubber a bit. If it was hard to re-install(you had to really force it in) the rubber might be torn up a little.
Chances are you are fine--it may just be dripping because the rubber will not seal against the rough sides of the valve body. It doesn't take much crud to cause a drip.--MIKE---
