Leaky Shower Head - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2012, 08:38 AM   #1
Rewards Points: 2,038
leaky shower head
I replaced a shower head. Now it leaks badly where it screws on. What's the name of the stuff you put on the screw threads to stop leaking?
Most times there's no clerk available to help when I go to the store. thank you.
Last edited by Startingover; 06-08-2012 at 08:39 AM. Reason: added words for clarification.
Startingover is offline   Reply With Quote
Old 06-08-2012, 10:24 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Teflon tape.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Startingover (06-08-2012)
Old 06-09-2012, 08:09 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Originally Posted by Alan View Post
Teflon tape.
Ayuh,... or pipe dope in a can...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Startingover (06-09-2012)
Old 06-09-2012, 08:37 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Teflon wrapped opposite way the shower head screws on.
Pipe dope is for black iron pipes or mostly for boiler fitting wouldnt suggest it on a shower head and or arm.
JetSwet is offline   Reply With Quote
Old 06-09-2012, 09:07 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 350
For 28 years I've doped every male thread on every type of pipe system.
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (06-11-2012)
Old 06-09-2012, 09:34 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Silver piping.... I always leave that type out of that equation, there's just no reason for it your not holding pressure in a shower arm nor sink drain tubes, traps, and offsets.
Old 06-10-2012, 07:46 AM   #7
Bondo's Avatar
Rewards Points: 342
Ayuh,.... On Silver pipin', I use white pipe dope,....
I can wipe off the excess, 'n it won't show a stupid white ring around the pipe, like excess tape does...
Old 06-10-2012, 09:09 AM   #8
seems to be a split opinion so I may try one thing on one shower and another on the 2nd shower.
P.S. I guess I'm better off using Pipe Dope because there are only about 3 threads on the stem. That's probably not enough space to wrap Teflon Tape.
There's one of those things attached, (which I'll leave) that has a button to shut off the water while you shampoo. A water saver. That connection is what has a very shallow place to screw on the shower head.
Old 06-11-2012, 07:25 AM   #9
How about if you use a rubber washer. It can also help you to control the leakage. In fact I think that ay be this s reason that your are facing this issue.
paul parker is offline   Reply With Quote
Old 06-11-2012, 07:45 AM   #10
paul,
there's really not enough space for a washer. Very, very shallow edge to screw the showerhead on, with that 'water saver' between the main stem and the showerhead I'm trying to attach.
otherwise, a good idea. thanks
Old 06-12-2012, 09:15 AM   #11
think I fixed it yesterday. Used pliers and tighten it as much as I could. That stopped the remaining leak.
Will try that on the outside spigot.
How can change the shower head angle? pennywise Plumbing 3 04-27-2012 04:19 PM
Threaded shower head connection too close to ceiling anygren Plumbing 6 10-11-2010 02:41 PM
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 09:13 AM
Handheld shower in addition to fixed head OnTheGo Plumbing 4 03-25-2010 12:31 AM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 06:49 PM
