Leaky Shower Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2012, 10:30 PM   #1
long island, NY
leaky shower faucet
Reluctant DIY plumber here My skill level is "beginner". Have replaced several sink faucets and sink drain assemblies... no more than that. Never tried to fix a faucet before...
Because the shut-off valve is hidden within the wall (tiled on both sides!), I want to make sure I know what I'm doing, because I'll have to shut off the main to the house until I'm done with the repair. (Hence my apprehension!) The goal is to avoid a costly tile job right now. (We have maxed out our DIY budget for the summer already!)
We have a 2 handle shower/tub faucet (with diverter) (cheap- "sterling" brand from 1975). The cold water valve is leaking. (I indend to replace both.) Online, some mention replacing a series of screws and washers (ex. http://www.stemdoctor.com/stdcom/def...5-68c1335aa569) and others mention having to hunt down a specific cartridge.
Here are my questions:
Do you think we will have to replace washers/screws, or cartridges? Since I'm hardly intelligible in plumbing lingo, what should I bring to the plumbing supplier to ensure I get everything I need?
Do you think I will even be able to find all the necessary parts there? (My worry is that it isn't a well known brand and it's almost 40 years old. I don't know how standardized these parts are.)
Is it possible to replace the whole faucet (or at least the visible portions) to basically give the shower a cheap facelift while I have the water shut-off anyway? (Can I get compatible new handles and tub spout?)
I'm presuming it's impossible to replace the whole faucet assembly without wall access.... (this is what I really want to do)
Thanks for your help!!!!! fingers crossed that we're not bathing at the Y next week!
diy'er on LI is offline   Reply With Quote
Old 09-02-2012, 10:48 PM   #2
DIY staff
Rewards Points: 7,174
Sterling is now owned by Kohler--so you have a good chance that parts are still available---
If you can remove the plastic handles and photograph the stem and nut assembly---someone here will be able to walk you through the process---
You should be able to remove the guts---take them to a plumbing supply house and get new---
Worse case---photo the parts and send to Sterling for ID and have them send parts.
As to replacing the trims? Ask them if replacements are still available---
Old 09-02-2012, 11:11 PM   #3
long island, NY
removing the handles is simple. They're metal and have an unhidden screw right in the middle. I'll take a pic tomorrow.
It's reassuring that I might be able to get replacement bits.
Thanks so much for your input. I'd be much less apprehensive about this little job if I didn't have to shut off the main... But alas, the builders apparently never heard about access panels
Old 09-03-2012, 06:33 AM   #4
DIY staff
Cheap thinking----shut off valves on a bathroom would make servicing the room so simple----yet they are seldom installed.
touchy shower faucet crosssums Plumbing 1 02-08-2012 05:08 PM
Help with Replacing a Shower Faucet adodd87 Plumbing 17 01-21-2012 10:21 PM
Need help. 1 shower faucet for 2 shower heads? Downshift93 Plumbing 4 11-08-2011 10:43 AM
I thought I put it back together properly: leaky shower valve (Matco-Norca) shuuy Plumbing 1 06-18-2009 11:44 AM
Does not fully go from faucet to shower desimonkey Plumbing 1 04-21-2009 03:59 PM
