I thought i had this fixed, but apparently not. Last night my wife was showering, and water was coming down in the pantry in the kitchen below....
I have attached a picture of the shower floor. I tried to put some silicone caulk around the "gasket" on the shower floor. I call it a gasket, but it is a plumbing fixture that has a ring that sits on top of the shower floor, and a 1.5 in pipe attached sits on top of the drain out. If I press down on the floor near the gasket, I can see where the gasket and the floor separate, thus allowing water to leave through a different avenue than what we want.
I have the pantry area opened up, so I can see the P Trap for the shower. I watched the water running down the side of it last night while the wife showered, before I ran upstairs and told her to end the shower! I am thinking of cutting a board and putting it under the trap, and having it end on the shelf below (about 18 inches). If I make the board 20 inches, and jam it in there, hopefully it might push the arrangement up in the shower. If I can do that, what should I put under that ring? Plumber's putty? Silicone? Should a rubber gasket or something else be under there as well?
What is under the base of the shower floor? It shouldn't just sit on the subfloor. I usually pour a bed of concrete or mortar mix. It keeps from giving it play. Try changing out the drain assembly if you have access. Several kind out there that should satisfy you. Some have a tool you stick in the top part of drain the tightens down the gasket. I believe it's made by Oatley. Home Depot/Lowe's should carry it. Good Luck
1. The floor of the shower pan should not flex up and down. Open up the ceiling and support it properly.
2. The Shower pan should have a steel well (Cup if you will) into which an EPDM Donut is pressed down around the pipe. If yours does not have this, you need a good EPDM gasket between the top flange of the drain outlet, and the flange of the shower pan. and a way to pull down on the gasket. Threaded Tail Piece? I would even coat the gasket with butyl cut off sealant on both sides of the gasket and clean up with alcohol. The problem is going to be building up the drain inside the shower.
Your main problem as I see it, is pumping of the shower pan. This must be stopped to ever get a good seal. A fernco rubber trap would help, because its flexible, but you have to secure that pan.
The problem with gluing is that many of these pans are made of (Chlorosulfanated Polyethylene) CSPE not PVC, and gluing is not an option.
First thing I would do is replace the drain assembly. IF YOU CAN. Is the drain molded to the shower pan, or does it have a nut on the bottom that will come off and release the drain?
I would use this drain every time, but my boss only likes them to be used on repairs.
Secondly, I notice the shower has been painted. Is that something that was done by you, or was it like that when you moved in? Possible reasons for that = covering up old failed gelcoat. If you say the floor is flexing like that, it very well could be trashed already. Hard to say for sure without looking at it.
Lastly, after replacing the drain assembly and re-installing the piping, make sure the drain line has good grade on it and by all means put some kind of support on the p-trap (use a solvent weld p-trap on 2nd floor) even if it's just a piece of plumber's tape wrapped around it and screwed into the joists. Something to keep it from dropping out, because this does happen quite frequently.
It looks like the drain is molded to the shower pan, but I will pull off the baseboard in front of the shower to see better. Hopefully this will give me more info.
I did some tests, and the flexing is so minimal, that I can barely get a razorblade between the drain and floor of the shower, now I am not convinced the flexing is my trouble.
If I go into the kitchen and grab the ptrap and try and move it, my wife says the shower drain moves from side to side a little, but if I push up on it, no movement (I was hoping pushing it up would allow me to add more silcone under it, but not gonna happen.
I wonder if the trap, like you said "dropped out". This was no minor leak last night while my wife was showering, this was probably 3/4 gallon a minute coming down the drain pipe.
I did not paint this, so it might be - as you said - someone's effort to cover up an already failed shower. When we bought the house, the ceiling in the pantry area was already opened up, so they knew they had a problem. I thought I had fixed it by putting some calk around the drain, but I don't think that's done it.
It almost looks like the molded drain portion of the shower is just sitting on the drain pipe when I look at it from the top. May be time to call a plumber......
The jack rabbit's cool- a good choice.
The only thing I'd do different is use a solvent weld drain. My reasoning is if all the deflection is not dealt with, the drain will flex at the gasket and may eventually leak. If the ptrap is allowed a slight amount of movement, the deflection will transfer down from the glued drain.
Ideally though, the base needs to be stabilized.
I agree with everyone else that you should replace the drain altogether, but I'd stay away from any drain that uses compressed rubber or neoprene to make the seal around the tailpiece. Those are (in my book) solely for those instances where there's no access from below to put in a socket welded (i.e. - glued) drain fitting - such as a shower on a concrete slab; or if you don't really care about what's underneath (like a crawlspace with dirt floor).
I'm replacing a drain next week. Its between a joist and a heat duct. I was researching online for the latest and greatest drain tool and I swear I saw a plastic drain like the jack rabbit. I'm going to resume my search:thumbup:
How can it be a molded drain yet as you say- moves side to side?
Is the pipe moving or the drain body itself moving?
Is there a large nut under the shower pan?
OK, so at the risk of being flamed, I'm going to ask a few questions! Be kind, lol!
If I look up from the pantry, first it's very tight, lots of beams, boards, strapping, etc. I cannot see a large nut or anything like that with the PVC. It *looks* like it's all soldered together. Again, only with what I can see right now, that's how it looks. I can see up to the subfloor.
Would the nut be under the subfloor? If not, how would you get to it? is there a way to get under the shower other than opening the ceiling more?
I know you talked about the "shower pan", that must be above the subfloor yes? I just wonder because like you all pointed out, generally you sit the shower floor on mortar to make sure you don't get any flex.
thanks for all the help! I'm new to this, so one step away from calling the plumber! Not sure how many hour job this would be, or even what their hourly rate is, so trying to fix it up myself if I can.
The nut would be above the subfloor. Jammed up right tight to the bottom of the shower base.
Sometimes you have to open the subfloor up a little bit bigger to get this type of repair done (we usually make a 5 or 6" hole when we set new showers because of this) but you have to be careful not to hit the shower base with whatever you're cutting with.
In that case it might be screwed in from above. There are a few different styles. If the drain fitting itself is moving from side to side, it's not molded to the base.
OK, so here's a picture from below. It is very cramped, and like i said, a pretty tight space. Basically, when we bought the house (a foreclosure), they had cut out a portion of the top of the pantry, then a portion of the ceiling above, so they could get at this drain pipe. This is the best picture I could come up with.
A few notes:
I had the wife move the drain pipe in the pantry then went up to the shower as she said she saw the drain move when I did this. It does move, but it's so minuscule as to be meaningless. Like pushing in on a window and it moves 1/64 of an inch, it doesn't matter.
Maybe you can see in the picture (more than likely not) but the hole coming through the subfloor is just wider than the drain pipe, so like Alan said, I would have to open up the subfloor more to see what's going on.
I will be calling a plumber tomorrow it looks like!
First thing was to widen up our view, so cut out the strapping, cut out more sheetrock, etc. Then cut the floor under the shower so we could even see the nut. There it was!! A few taps with the hammer, and this thing isn't moving. Harder taps, much harder taps, and one side of the nut breaks off.
The nut was glued on...We had to take a grinder and get it off that way. So now we can get the drain out and start to think about the new one.
First though was to stabilize the shower base, which had absolutely nothing under it. No shims, no foam, no mortar, just a lot of air. That was a pleasure, pushing boards and shims as much as possible, then using expanding foam for the rest of it.
Alan, the plumber used almost the very same drain fixture you showed! Just a different brand name.
So I'm going to let it all set in for a night then I should be back in biz.
Thank you much to all who contributed, I thought I would update you all and say "this issue is resolved"!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
