Leaky Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2006, 07:16 PM   #1
Question
Leaky pipe
My water pipe is leaking where it was tapped into with a self-tapping connection fridge ice maker. Can this be repaired, or repair spot and tap in a different spot?
rmh218 is offline   Reply With Quote
Old 11-08-2006, 07:47 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Fix that spot, stay away from self tapping valves, for this very reason. run a new line from under the kitchen sink with a real 1/4" shut off valve.
Ron The Plumber is offline   Reply With Quote
Old 11-09-2006, 04:08 PM   #3
If you try patching the leak, you will always have to worry that it could fail and flood the area. As Ron said, the self tapping connections are a sad way to tap a line. The hole is so small, it easily gets clogged and the next problem is the leaks. Use a coupling to repair the bad spot in the pipe. Cut through the center of the hole (all the way through the pipe) and then install a coupling or, better yet, a tee for the frig water connection.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Leaky Steam Heat Pipe NJE HVAC 6 01-30-2007 08:26 PM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 06:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
