Leaky Kohler Gasket - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2011, 04:45 PM   #1
Question
Leaky kohler gasket
Hello,
I had an old kohler toilet with the famous triangular gasket to connect the tank to the bowl. It was leaking apparently from that part each time you flush.
I changed the gasket today (and the rest as well), place the whole thing back (at least 3 times..) and it still leaks the same way (a small flow in the back, apparently going through the 3rd hole in the back). Oh it's leaking also only when you flush.
I'm starting to run out of options.
Any ideas, suggestions?
Nicolas
nrdufour is offline   Reply With Quote
Old 10-16-2011, 07:38 PM   #2
Mark Potter's Avatar
Rewards Points: 150
Originally Posted by nrdufour
Hello,
Nicolas
It's most likely cracked it sounds like. Put some food coloring in the tank it will come out we're the crack is. It's probably a chip by the gasket.
Mark Potter is offline   Reply With Quote
Old 10-16-2011, 08:10 PM   #3
Thanks Mark!
I will probably look at that and replace the whole toilet if needed!
Old 10-16-2011, 09:04 PM   #4
DIY staff
Rewards Points: 7,174
This fix is not a recommended fix---However it can work--
Remove the tank (again) make a thick roll of plumbers putty and place it around the hole in the stool--
Reinstall the tank---and pray--Mike---
Installing a Kohler triangle gasket. liquidvw Plumbing 6 08-01-2011 01:26 PM
Should gasket overlap spud washer on toilet? boarderx Plumbing 19 01-04-2011 12:40 AM
Tank-to-bowl gasket help n0c7 Plumbing 7 01-02-2011 07:05 PM
Carrier 58msa burner gasket mdflyer HVAC 12 12-26-2010 02:41 PM
Tank gasket problem firemanter Plumbing 1 01-01-2009 11:26 PM
