Leaky Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2013, 11:08 AM   #31
Originally Posted by jmon View Post
Excellcent saveme. Sounds great. Let us know how everything works out for you. Thanks.
Ok. Here is how things worked out for me and my leaky boiler. I called the company and got a replacement boiler as the one I had was still under warranty. A plumber gave me an outlandish quote to swap the boilers. I broke the union, cut the copper pipes and hauled it back to Lowes where I picked up the new one. I got some pipe dope, shark bites and went back and replaced the boiler myself. All the pieces went back in as before, however, I did a stupid thing. I pulled on the black iron pipe to get the union to join with the black iron I had connected to the boiler. There was about a two inch gap to make up. I loosed the strap and pulled the iron down and jointed the pipes. I put soapy water on bends and joints and no leak. Friend said I should have just gotten more iron to make up the 2-3 inches. So far so good. No leaks that I can detect, no gas smell and new boiler is making hot water nicely.
Thanks for all of your help and comments as I am NOT a DIYer. Based on your input and a few you tube videos I was able to tackle this project myself. Thanks again.
Saveme$ is offline   Reply With Quote
The Following User Says Thank You to Saveme$ For This Useful Post:
jmon (10-31-2013)
Old 10-31-2013, 12:13 PM   #32
Rewards Points: 282
Your welcome saveme. Glad everything worked out for you in the end. Your experience may help someone else. Thanks for sharing the end result with the forum. Make sure your gas line does not have too much stress on it.
jmon is online now   Reply With Quote
Old 10-31-2013, 04:15 PM   #33
Rewards Points: 1,590
" I loosed the strap and pulled the iron down and jointed the pipes. I put soapy water on bends and joints and no leak. Friend said I should have just gotten more iron to make up the 2-3 inches. So far so good. No leaks that I can detect, no gas smell and new boiler is making hot water nicely. "
Did you ever make up the 2-3 inches with new pipe or is it still under stress and at increased risk for breaking?
bob22 is online now   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
jmon (10-31-2013)
Old 10-31-2013, 05:27 PM   #34
Rewards Points: 282
Saveme, Bob brings up a very good safety point. Make sure you do not have too much stress on the gas pipe. If there is a lot of stress on it, get that extra piece of pipe installed. They sell 2 or 3 inch threaded gas pipe at any big box or plumbing supply store. Thanks and have a safe Holiday Season.
Old 10-31-2013, 06:06 PM   #35
Rewards Points: 1,952
Your original quote was it was leaking. That is where you should have called Lowes and tell them it was leaking. Your new tank would have been in your drive.
Old 11-02-2013, 05:57 PM   #36
I will go and get the extra pipe piece to release the stress. Not sure how much stess its under. When loosened the union thecblack pipe sprang up. I gotvexact same boiler and there was the gap. I suspect it was always under stress. ..Working do well I hate to mess 2ith it but better safe than sorry.
I'll grt the spare piece and do it next weekend when I have the time. Should be ok till then right?
jmon (11-03-2013)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 05:44 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
