Old 11-17-2010, 10:12 PM   #1
Citrix & Cisco Ops
Leaky fitting on main supply-side
Hi everyone,
I've seen some forum posts in regards to leaky fittings but I wanted to see if the rules change when dealing with anything regarding the main.
While moving some furniture this evening, I mmmmmmight have accidentally bumped the supply side of my main. One of the fittings is dripping every 20-30 seconds or so. The fitting is after the shutoff valve, fortunately.
Until I can get a plumber out here for a permanent fix, is it ok to just shut it off and use plumber's epoxy? Or do I need to go to defcon 1 and use a plumbing emergency service?
Jack
RedHelix is offline   Reply With Quote
Old 11-17-2010, 10:17 PM   #2
for a slow leak like than it's ok. He'll have to replace a good section of pipe anyway to fix it, so yeah shut it off and do your thing. that will make less of a mess
immeraufdemhund is offline   Reply With Quote
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 11:02 AM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 08:26 PM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 01:22 AM
Ground Main Water Supply? blueboy27 Electrical 17 11-04-2007 01:38 AM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 11:33 PM
