-   -   Leaky fitting on main supply-side (http://www.diychatroom.com/f7/leaky-fitting-main-supply-side-87004/)
RedHelix 11-17-2010 10:12 PM
Hi everyone,
I've seen some forum posts in regards to leaky fittings but I wanted to see if the rules change when dealing with anything regarding the main.
While moving some furniture this evening, I mmmmmmight have accidentally bumped the supply side of my main. One of the fittings is dripping every 20-30 seconds or so. The fitting is after the shutoff valve, fortunately.
Until I can get a plumber out here for a permanent fix, is it ok to just shut it off and use plumber's epoxy? Or do I need to go to defcon 1 and use a plumbing emergency service?
Jack
immeraufdemhund 11-17-2010 10:17 PM
for a slow leak like than it's ok. He'll have to replace a good section of pipe anyway to fix it, so yeah shut it off and do your thing. that will make less of a mess
