#1 |
leaky bathroom faucet; how do I change washer
My bathroom sink faucet is leaking and I believe the washer needs to be changed.
It is a one handle faucet. Where is the washer? Do I have to somehow figure out how to remove the handle? The handle lifts up and you can go either way for hot and cold. there are no visible screws that I can see. Any help would be appreciated. Thanks |
#2 |
(the original)
I'd have to know a lot more about your particular faucet, but here's a link that should be useful: http://www.diynetwork.com/diy/pl_fau...270854,00.html
#3 |
Custom Cabinet Maker
Yummy; sorry cant stop smilin
![]() First off if single lever, NO washers. Second what brand? Delta seems most poplar. Third you will find a small set screw either underneath or in the back of the handle. TURN OFF THE WATER B4 YOU TRY THIS AT HOME!!!!!!! ![]() If it is a delta you can get a rebuild kit from eithet Hd or Lowes. Quite simple to replace. JackM |
#4 | |
leaky bathroom faucet; how do I change washerQuote:
The brand is Zucchetti, by Natphil. There is a screw underneath the spout. If there is no washer, then how would I fix the leak? (Take that grin off your face now. )
#5 |
Oh Yummy Yummy I am still smilin right down to my Tummy
.Well let me see, so far the unfound screw was right where I thought it was. Hmmmmmmmmm will check the Universe for ya. Jack |
#6 |
Yummy Yummy, try this; you should be able to get answers and parts maybehttp://www.luxuryhomeproducts.com/natphil/index.htm. Sorry not a link,it will not co-operate LOL sounds familiar eh??????? anyway that page will get you a phone number and hopefully solve all the problems. If so you may worship me later LOL LOL
Jack |
#7 |
Builder/Remodeler
If it's the faucet I'm thinking of, you'll need to unscrew the barrel handle from the cap to access to set screw. Once you have the cap off, you'll need to turn the water off to take it apart any farther. Sometimes, the handle screw will also hide behind a logo plate or hot/cold label.
A lot of modern styled faucets use enclosed cartridges for the guts. There may be rubber washers around the ceramic heads...but you'll be hard pressed to find them at a home center, or even a plumbing supply for that matter. Your best bet would be to contact the manufacturer for a repair kit.
Christopher Wright, WrightWorks, LLC To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 |
Thanks for the info. to both of you Jack and Chrwright.
That line Jack, has my faucet. I will contact the manufacturer and get some help there. Thanks |
#9 |
I meant to say that link has my faucet.
You still haven't told me why you are smiling? |
#10 |
How can one NOT smile in the presence of such a wonderful, sweet,bodacious,super callifragilisticexpallodous, fantasmagorical,person such as yourself?
Jack |
#11 |
such a nice compliment.......
I always knew that being 5'2", 250 lbs, and 65 years, was bodacious..........
#12 |
to a 3' , 300#, 125 yr old troll You shure are
#13 |
#14 |
By the way, I looked up that link that you gave me, and they emailed me back with a toll free number for the manufacturer who will help me.
Thanks very much. |
| Display Modes | |
| Wiring in New Addition? | sandyman720 | Electrical | 6 | 11-27-2011 04:34 PM |
| Repair outdoor faucet? | mx13 | Plumbing | 3 | 04-09-2007 07:08 PM |
| Location of 220 and 110 outlets for dryer and washer | JAJJ | Electrical | 2 | 08-07-2006 10:16 PM |
| Installing exterior faucet to washer line? | skellies | Plumbing | 3 | 06-18-2006 09:19 PM |
