Leaky Bathroom Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2010, 07:02 AM   #1
New Bathroom faucets and sinks. My drain is leaking where the sink meets the drain. Sink and drain did not come with a washer or o-ring any advice?
vanbellet is offline   Reply With Quote
Old 02-28-2010, 07:54 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Ayuh,... Take it apart,+ reseat it in plumber's putty...
Bondo is online now   Reply With Quote
Old 02-28-2010, 08:18 AM   #3
Dose the plumbers putty go underneath the silver part of the drain?
Old 02-28-2010, 11:13 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Yes.
10char
Journeyman Plumber
Old 02-28-2010, 03:54 PM   #5
Oh no...... I'm not a plumber but I think that makes the best sense. My y plumber guy keeps tightening the under portion of the sink . He said it takes at least 3 weeks of tightening to make the new sinks adhere to the drain, this doesn't make any sense to me but I'm a female and he's been a plumber for 10 years...Can you confirm if the fit is right with the plumbers glue it shouldn't leak at all? New sinks faucet and drain so it should be ok right?
Old 03-01-2010, 07:56 AM   #6
Bondo's Avatar
Rewards Points: 338
Ayuh,... He's Full of it,... It should seal from the get-go...
Old 03-01-2010, 10:04 AM   #7
Doing it myself
Alan's Avatar
Sometimes they leak a little from the threads on the drain assembly. We put a little dab of caulking on the threads so that when the nut is tightened, the threads are sealed.
Journeyman Plumber
Old 03-01-2010, 01:53 PM   #8
Rewards Points: 352
should be watertight at the end of installation. If it's not tight it's not right!
plumberinlaw is offline   Reply With Quote
Old 03-01-2010, 04:45 PM   #9
Thanks for all the advice.
Sewage type smell coming from bathroom shower drain majorchamp Plumbing 29 06-25-2012 11:08 AM
2nd story bathroom, drain &vent, please help!!! serik Plumbing 4 07-15-2009 08:33 AM
Bathroom Sink Drain (Broken from wall to Ground) bli182nk Plumbing 2 01-11-2009 08:52 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 10:36 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
