Leaky Base - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2012, 02:41 PM   #1
leaky base
i bought house with elger toilet last yr, toilet leaks, called plumber he put flange and wax ring and new bolts and everything and it still leaks around base. is elger toilet sealed? why is it leaking and where would water come from to end on floor?
bpasser is offline   Reply With Quote
Old 03-24-2012, 11:16 PM   #2
Rewards Points: 13,458
It's common to have to go back and have to snug up the bolts again once the toilets been used a few day and set the wax ring. Just sit on the toilet and see if it wiggles, if it does simply give the nuts a turn or two.
A blocked up drain can also cause it to leak.
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 09:02 AM
Bathroom project: in floor heating, slc and shower base Me xeno Flooring 1 01-20-2012 07:12 AM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 07:52 AM
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 07:40 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
