Old 10-01-2011, 09:20 AM   #1
Leaky American Standard Connoisseur Faucet
Hi all,
I've got an American Standard Connoisseur faucet in my kitchen. When the faucet is on it leaks up from between the spout and the handle. The amount varies, and it also changes if you move the spout back and forth while the faucet is on. I'm guessing a new spout seal kit, cartridge, or spacer with o-rings are needed, but I hate to just throw parts at it and spend more money than necessary. Any ideas on what it might be?
http://americanstandardparts.faucetd...0parts_407.pdf
scottyv81 is offline   Reply With Quote
Old 10-01-2011, 09:27 AM   #2
Super Moderator
Most likely the cartridge---Good luck finding parts---American Standard is seldom repaired and few places stock parts.
oh'mike is online now   Reply With Quote
Old 10-01-2011, 11:18 AM   #3
Yea I'm not the original owner so no warranty parts for me. The guy I talked to at the big box store said they don't stock American Standard parts because there isn't any money in it due to the warranty. American Standard sells the parts direct, and there is a place on-line to order them from. Would you suggest I do the spout seal kit (the o-rings around the cartridge) at the same time as the cartridge? For what the parts cost I'm almost leaning toward just getting a new faucet.
Old 10-01-2011, 11:09 PM   #4
Super Moderator
I'd simply replace it,too.
A customer of mine has a similar situation---American Standards customer service and parts is stink-o
He gave up after numerous calls and bought a new Moen.
By the way---the parts for Moen and Delta are stocked at the Depot and those parts are free from the makers---the sad truth is that American Standard is disposable---Mike---
Old 10-01-2011, 11:26 PM   #5
Doing it myself
Alan's Avatar
I think you mean SOUTH American Standard.
I hate to say it, because I just bought an old house with 2 american standard cadet 3 toilets, and an american standard tub shower valve in an exterior wall.
I've pulled countless toilets out of boxes and found them to be anywhere from 1/8 to 3/8 out at the base of the bowl. 1/8 isnt' that bad, but 3/8 of caulking on one side is an eyesore. We recently repaired an old A/S shower valve for someone, and the lack of availability on parts was shocking. Once we finally got it it was somewhere in the realm of 100 bucks for a stinking cartridge.
So far, for the money, Moen is my favorite. Delta second. If price was no object, i'd go Kohler.
Journeyman Plumber
Old 10-03-2011, 03:05 PM   #6
Cool
It seems that the correct RP's to fix the faucet are:
060343-0070A,
SPACER WITHO-RINGS. 023603-0070A, CARTRIDGE SCREWS and
023529-0070A
CARTRIDGE. But first check if the cartridge is well tighteneed. If the spout moves and is leaking from the middle section of the body...the cartridge is not completed tighteneed.
mr fix
Last edited by mrfix; 10-04-2011 at 05:02 PM. Reason: http://americanstandardparts.faucetd...0parts_407.pdf
mrfix is offline   Reply With Quote
Old 10-04-2011, 05:05 PM   #7
Cool
customer service contact
http://www.americanstandard-us.com/contactUs.aspx
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 09:45 AM
Leaky American Standard bathtub faucet t1r2u3s4t Plumbing 7 12-30-2010 02:26 PM
Good grief, 1956 American Standard bath faucet repair problem David911 Plumbing 4 02-27-2010 05:33 PM
Godman, Lennox, or American Standard homeowner12 HVAC 2 10-13-2009 06:54 AM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 09:33 AM
