Leaky American Standard Bathtub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2010, 06:09 PM   #1
Rewards Points: 12
Question
Leaky American Standard bathtub faucet
Hi all
First time poster here with an old AS tub that goes *drip drip drip*. It's a single handle pull out type. I managed to take the handle and the bolt that align the shaft out but not sure how to go from there to replace a rubber seal or cartridge. Any help would be greatly appreciated.
Thanks in advance,
M
t1r2u3s4t is offline   Reply With Quote
Old 12-15-2010, 01:14 PM   #2
Just a guess, but see if that chrome sleeve screws off. Then you may be able to see what is holding the stem/cartridge in the valve??
broox is offline   Reply With Quote
Old 12-15-2010, 01:26 PM   #3
Rewards Points: 12
Good point. I'll give that a shot. Thanks!
Old 12-22-2010, 07:16 PM   #4
Rewards Points: 12
So I managed to remove the chrome tube. It seems purely decorative and I'm stuck again (no punts intended). The second picture shows a white plastic spacer inside the tube that doesn't seem to move when the stem is pulled in or out. The brass nut that I took out to reveal this spacer seems to control how tight the stem is to pull/push/turn. With the nut out I put the knob back on and tried to pull the stem straight out but it didn't bulge. There are two screws holding the valve body into the whole assembly but I haven't dare touching that yet. It seems like messing with those could really cause major leakage on the assembly itself, not just through the sprout.
Any thought?
Thanks,
M
Leaky American Standard bathtub faucet-img_0118.jpg   Leaky American Standard bathtub faucet-img_1369.jpg
Old 12-22-2010, 07:18 PM   #5
Rewards Points: 12
PS: The 2 screws are flat head and can be seem on the second picture in the original post. They are on top of the valve to the left and right.
Old 12-22-2010, 08:03 PM   #6
I've never seen an AS shower valve with a stem, not a cartridge. Wondering how you know its AS? I don't see any markings on the trim or valve. Maybe look at the underside of the escutcheon to see if there are any marks. Also, maybe peel back the metal lath (carefully) and see if there are any markings on the valve body.
the_man is offline   Reply With Quote
Old 12-22-2010, 08:12 PM   #7
Rewards Points: 12
The escutcheon says American Standard, so I'm assuming the valve is AS as well. I'm not sure if it's a stem or a cartridge either. The valve kinda looks like a Moen, but I don't see the clip that locks the cartridge in...
Old 12-30-2010, 01:26 PM   #8
Rewards Points: 12
So I figured out the model of the faucet, it's indeed an American Standard N 1030. The part diagram is in the below pdf.
http://www.plumbingpartsdepot.com/aspushpullshwr.pdf
Now I can't for the life of me figure out how it works to fix the leak. Anyone familiar with these faucets?
Thanks!
Old 01-13-2015, 04:06 PM   #9
Rewards Points: 2
Too lat for the OP but I just did mine again.
The valve is a 1030, the rebuild kit is a 3492.
You will need...
  • 9/16 wrench
  • Allen wrenches
  • Plumbers silicone grease
  • Large flat screwdriver
  • #2 Philips Screwdriver
  • Fine brass wool
  1. Take the handle off by means of the Allen head post on the bottom.
  2. Take of the escutcheon by removing 2 Philips screws.
  3. Remove valve front by removing two brass slotted screws at 4 & 8 o'clock. Remove large square gasket and 2 smaller square gaskets still in body in wall ( they may also be on the part you removed from the wall).
  4. Remove 9/16" gland nut around front of shaft.
  5. Pull shaft out from rear and clean with brass wool or extra fine Scotchbright in a circular motion around shaft, clean and lube with silicone grease. Remove and replace 2 white gaskets in front hole, lube.
  6. Remove the two caps on top with either a 9/16 wrench across the flats or a very large screwdriver (best to do this one at a time). Replace gasket on each cap, SS springs and stems.
  7. Inside each hole is a replaceable valve seat that is removed with a 3/8 Allen wrench, lube rubber on replacement and install rubber side up.
  8. Insert new SS springs and stems, spring is up. Reinstall caps with new gaskets.
  9. Insert spindle from rear to front, tighten gland nut.
  10. Lube remaining large square gasket and 2 smaller square gaskets, use enough lube to stick them to the face of the body still in the wall.
  11. Carefully put the valve front back on the body in the wall, taking care not to dislodge the gaskets, and turn in the 2 large brass screws, tighten evenly.
  12. Temporarily replace handle, there is a notch in the end of the spindle that should face down when installing the handle.
  13. Test for leaks.
  14. Replace escutcheon and handle.
I like to have a rebuild kit on hand before I do this kind of work but in this instance there was some dirt in the valve sat that was causing my leak. I rebuilt it anyway, my time is worth more than the $16.00 for the kit. If you have one of these showers may be worth it to get a spare to keep around. They are discontinued but Home Depot carries the replacement.
Recoil Rob is offline   Reply With Quote
The Following User Says Thank You to Recoil Rob For This Useful Post:
SeniorSitizen (01-13-2015)
Old 01-13-2015, 04:40 PM   #10
Rewards Points: 12
Hi
FYI, I ended up using the Danco kit ordered from homedepot http://www.homedepot.com/p/DANCO-Rep...0713/202070992. It works fine.
PS: is that RecoilRob from svrider?
Tags
american standard , bathtub , faucet , leaky
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Good grief, 1956 American Standard bath faucet repair problem David911 Plumbing 4 02-27-2010 04:33 PM
Godman, Lennox, or American Standard homeowner12 HVAC 2 10-13-2009 05:54 AM
Very low pressure on bathtub faucet/ showerhead Mermarisa Plumbing 7 10-10-2009 11:47 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
