Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2009, 06:25 PM   #1
Leaks
I have installed a vessel sink and it leaks from under the bowl am i missing a step?
nannette is offline   Reply With Quote
Old 12-17-2009, 06:29 PM   #2
My vessel bowl keeps leaking from underneath the bowl
Old 12-17-2009, 06:33 PM   #3
Leaking bowl
MY VESSEL SINK IS LEAKING FROM UNDER THE BOWL. WAS I SUPPOSED TO PUT PUTTY OR SOMETHING UNDER BOWL AND IF SO HOW LONG DO YOU WAIT FOR IT TO SET?
Old 12-17-2009, 07:11 PM   #4
whats a vessel sink? is it the type that sits on a counter, if so you have missed putty on the bowlside or an improper gasket fit on the bottom side
Old 12-17-2009, 07:37 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... Nannette,... You're stuttering,... Use your refresh button after you use the back button,...
Your posts will appear...
Yes, I believe either putty or a gasket is necessary,...
The putty is stiff enough than it can be use immediately....
Suzuki atv leaks gas form carb lemoncoke Automotive Repairs 2 12-28-2010 09:54 PM
Ridge Vent: Cause of massive leaks? ShortEdged Roofing/Siding 28 08-26-2010 11:15 PM
T&P valve (new) leaks also.... rubani Plumbing 7 11-09-2009 03:13 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
T&G Floor Leaks newguy4 General DIY Discussions 2 11-07-2005 11:24 AM
