Leaking By Well Pipe Entering House - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2013, 09:40 PM   #1
Rewards Points: 664
Leaking by well pipe entering house
Originally I thought the water accumulating in my crawl space near the pipes entering my house from the well was rain water. I pumped the water out and we have not had heavy rain recently. However, the water is back and has accumulated in the crawl space.
In my front yard there is a PVC pipe sticking up from the ground which I assume is my well. (I really do not know much about wells.) It is dry in that area. Under the house in the crawl space are black flexible pipes with a meter type gauge on it. The water seems to be pudding where those pipes come in. However, that is also the low point in my crawl space. I intend to inspect the crawl area when I pump the water out again, but is it possible the supply lines from the well are at fault? It seems the water pressure in the house is normal.
crescere is offline   Reply With Quote
Old 04-26-2013, 10:19 PM   #2
joed's Avatar
Rewards Points: 11,598
A private well would not have a meter on it. Can you take a photo of the device?
It is possible the water line from the well is leaking.
Old 04-28-2013, 08:57 AM   #3
Rewards Points: 664
Here is an overview of my crawl space with the well pipe nad electrical coming out of the ground.
Old 04-28-2013, 08:58 AM   #4
Rewards Points: 664
Here is the collected water after I pumped most of it out.
Old 04-28-2013, 08:59 AM   #5
Rewards Points: 664
Here is the gauge
Old 04-28-2013, 09:01 AM   #6
Rewards Points: 664
Do you think the water is coming up from the well pipe. It appears dry by the pipe in my front yard.
Old 04-28-2013, 11:03 AM   #7
Roofmaster
Rewards Points: 2,172
I think that your setup is dangerous, and should be completely re-vamped. Surface water is not supposed to be able to seep down into your well, thats how you get Cholera, Typhoid etc.
Old 04-28-2013, 11:15 AM   #8
Rewards Points: 664
I thought it was coming UP from the well. Please give details about being "re-vamped."
Old 04-28-2013, 12:19 PM   #9
Rewards Points: 664
I have just had this house for a few months and I am new to wells. I would appreciate any and all advice on well maintenance etc.
Old 04-28-2013, 12:55 PM   #10
Rewards Points: 582
where is the holding tank?????ben sr
Old 04-28-2013, 04:09 PM   #11
Rewards Points: 664
It is in the laundry room about 20 ft. or so away from the entrance to the crawl space. I also have a water softener there.
Old 04-28-2013, 04:16 PM   #12
Rewards Points: 664
It is hard to tell, but it appears that when I turn off the pump the water does not get worse. However, I will give it another day with no pump on to see if more water accumulates. I assume if the water stops it MUST be a problem with the well supply lines? It is raining now so I will also see if that is a factor.
Old 04-28-2013, 04:18 PM   #13
Rewards Points: 582
if you have a leak in the piping on well system..you should see a pressure drop on gauge... and the system will cycle without using water..ben sr
Old 04-28-2013, 06:46 PM   #14
Rewards Points: 664
I have turned the pump off now, but when it was on I did not hear any unusual cycling. Please fill me in on what to look for on the gauge pictured above. I have never owned a house with a well and I am not familiar. What should the reading be when it is acting normal?
Old 04-28-2013, 06:54 PM   #15
joed's Avatar
The first problem I see is what appears to be NM cable going down into the ground via a pipe. That needs to be underground wet rated cable.
As for the water, when the pump is running can you see water leaking out anywhere?
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Leaking between the meter and the house Stephen S. Plumbing 9 01-14-2010 07:51 PM
Leaking waste pipe Ailish Plumbing 2 08-06-2008 10:19 AM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
Leaking waste pipe guvlin444 Plumbing 5 09-30-2006 02:36 PM
