-   -   Leaking by well pipe entering house (http://www.diychatroom.com/f7/leaking-well-pipe-entering-house-178178/)
crescere 04-26-2013 08:40 PM
Originally I thought the water accumulating in my crawl space near the pipes entering my house from the well was rain water. I pumped the water out and we have not had heavy rain recently. However, the water is back and has accumulated in the crawl space.
In my front yard there is a PVC pipe sticking up from the ground which I assume is my well. (I really do not know much about wells.) It is dry in that area. Under the house in the crawl space are black flexible pipes with a meter type gauge on it. The water seems to be pudding where those pipes come in. However, that is also the low point in my crawl space. I intend to inspect the crawl area when I pump the water out again, but is it possible the supply lines from the well are at fault? It seems the water pressure in the house is normal.
joed 04-26-2013 09:19 PM
A private well would not have a meter on it. Can you take a photo of the device?
It is possible the water line from the well is leaking.
crescere 04-28-2013 07:57 AM
1 Attachment(s)
Here is an overview of my crawl space with the well pipe nad electrical coming out of the ground.
crescere 04-28-2013 07:58 AM
1 Attachment(s)
Here is the collected water after I pumped most of it out.
crescere 04-28-2013 07:59 AM
1 Attachment(s)
Here is the gauge
crescere 04-28-2013 08:01 AM
Do you think the water is coming up from the well pipe. It appears dry by the pipe in my front yard.
jagans 04-28-2013 10:03 AM
I think that your setup is dangerous, and should be completely re-vamped. Surface water is not supposed to be able to seep down into your well, thats how you get Cholera, Typhoid etc.
crescere 04-28-2013 10:15 AM
I thought it was coming UP from the well. Please give details about being "re-vamped."
crescere 04-28-2013 11:19 AM
I have just had this house for a few months and I am new to wells. I would appreciate any and all advice on well maintenance etc.
ben's plumbing 04-28-2013 11:55 AM
where is the holding tank?????ben sr
crescere 04-28-2013 03:09 PM
It is in the laundry room about 20 ft. or so away from the entrance to the crawl space. I also have a water softener there.
crescere 04-28-2013 03:16 PM
It is hard to tell, but it appears that when I turn off the pump the water does not get worse. However, I will give it another day with no pump on to see if more water accumulates. I assume if the water stops it MUST be a problem with the well supply lines? It is raining now so I will also see if that is a factor.
ben's plumbing 04-28-2013 03:18 PM
if you have a leak in the piping on well system..you should see a pressure drop on gauge... and the system will cycle without using water..ben sr
crescere 04-28-2013 05:46 PM
I have turned the pump off now, but when it was on I did not hear any unusual cycling. Please fill me in on what to look for on the gauge pictured above. I have never owned a house with a well and I am not familiar. What should the reading be when it is acting normal?
joed 04-28-2013 05:54 PM
The first problem I see is what appears to be NM cable going down into the ground via a pipe. That needs to be underground wet rated cable.
As for the water, when the pump is running can you see water leaking out anywhere?
