Leaking Water Main Shutoff Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2012, 03:16 PM   #1
Leaking water main shutoff valve
Hello!
I was about to get started on replacing a leaky laundry tub faucet, which was going to be an easy fix, even for a relatively new DIYer like myself. Went to turn off the main water supply inside the house and it started leaking at (1). The leaking stopped when I open the valve back up. I then did some searching on the internet and found that tightening the packing nut may solve the issue. As I applied pressure to the packing nut, I got some minor leaking from (2), which stopped when I stopped applying pressure.
Am I right in assuming that this might be a job for a more experienced plumber, or is there something else I'm missing here?
Thanks in advance!
Witz is offline   Reply With Quote
Old 09-23-2012, 03:35 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 350
If you're tightening the packing nut at (1) and your leaking at the meter connection(2) then you must have a bad meter gasket. It looks like a large hose bib washer. Contact your water company to replace it.
Old 09-23-2012, 05:07 PM   #3
Rewards Points: 12,824
And replace that old gate valve with a Ball valve, as well as any old steel fittings.
Is that gray tubing Quest? If so that needs to also go. It should say Quest right on the tubing.
There was class action suits long ago from the pipes and fitting bursting and develping pin holes in them.
Old 09-23-2012, 09:33 PM   #4
Thanks guys. Looks like I'll be contacting the water company first thing tomorrow.
And Joe...From what I'm reading, the Quest piping was a type of plastic piping, correct? This all appears to be galvanized to me. As for the valve and fittings...I will inquire when mentioning the leak.
Old 09-23-2012, 09:47 PM   #5
Anyone else notice what looks like 4" copper drain line running into the cast iron hub?
Old 09-23-2012, 10:06 PM   #6
Plumber
Rewards Points: 350
Yea, see it often in these parts. It's actually soldered to a brass hub adapter.
Took a bunch out a while back- doubled my wages when I cashed it in for scrap
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 06:00 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 08:46 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
