Old 08-31-2006, 01:20 AM   #1
leaking water main
I was helping my landlord move some plumbing the other day (he redoing to a downstairs bathroom) and we discovered the main water valve leaks when closed. It is a gate/globe type valve and leaks out the stem, so the problem appears to be with the packing and should be easy to fix (although we may just replace and save the valve for something less crucial), if we could shut the water off further upstream. I looked at the meter, but I see no obvious way to shut the water off there. I tried to down on the nut above the packing, but it didn’t want to move and I was afraid to crank on it.
The leak was manageable; we used a bucket and moved what we wanted to move anyway, but I like the idea of being the shut off the water to the house in case anything else goes wrong. (Actually it did: as soon as we turned it back on we blew about apart some piping going to the washing machine we never touched. It seems the previous owner thought you only had in insert copper pipe a little over 1/16” into an elbow before soldering. I figure that was just waiting to happen, and was glad it happened when I had all my plumbing gear out, but now I’m paranoid about the rest of the pipes.)
LanterDan is offline   Reply With Quote
Old 08-31-2006, 07:19 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
leaking water main
Call your water dept, they should be abie to help you in finding there shut off so you can work on yours,
Ron The Plumber is offline   Reply With Quote
Old 08-31-2006, 07:19 AM   #3
leaking water main
Call your local water authority and have them turn off the water at the curb. Then replace the valve.
If that is what you are asking?
redline is offline   Reply With Quote
Old 08-31-2006, 07:21 AM   #4
Journeyman Plumber
leaking water main
Beat you to the draw redline
Old 08-31-2006, 08:24 AM   #5
leaking water main
More On This Topic
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 1 for installing a ball valve. I am going to be installing a ball valve on this pipe. This pipe is a hot water pipe, and I know that because when I trace it back, it... Read More »
Hi! I'm Cathi Pare with the City of Santa Barbara Water Resources speaking to you today for expertvillage.com. We've already looked at the meter and we determined that there was water running through the meter so the next step is we want to isolate is it... Read More »
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 2 in our process of installing a ball valve. The next thing we need to do is locate our main water shut off, and we need to go ahead and turn that knob. Remember... Read More »
Main water shutoff problem GoodoleBob Plumbing 17 08-27-2008 09:53 PM
Replacing part of the Main Water line rgmetro Plumbing 2 04-12-2007 09:30 AM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 07:22 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
