-   -   leaking water main (http://www.diychatroom.com/f7/leaking-water-main-3721/)
LanterDan 08-31-2006 12:20 AM
leaking water main
I was helping my landlord move some plumbing the other day (he redoing to a downstairs bathroom) and we discovered the main water valve leaks when closed. It is a gate/globe type valve and leaks out the stem, so the problem appears to be with the packing and should be easy to fix (although we may just replace and save the valve for something less crucial), if we could shut the water off further upstream. I looked at the meter, but I see no obvious way to shut the water off there. I tried to down on the nut above the packing, but it didnít want to move and I was afraid to crank on it.
The leak was manageable; we used a bucket and moved what we wanted to move anyway, but I like the idea of being the shut off the water to the house in case anything else goes wrong. (Actually it did: as soon as we turned it back on we blew about apart some piping going to the washing machine we never touched. It seems the previous owner thought you only had in insert copper pipe a little over 1/16Ē into an elbow before soldering. I figure that was just waiting to happen, and was glad it happened when I had all my plumbing gear out, but now Iím paranoid about the rest of the pipes.)
Ron The Plumber 08-31-2006 06:19 AM
Call your water dept, they should be abie to help you in finding there shut off so you can work on yours,
redline 08-31-2006 06:19 AM
Call your local water authority and have them turn off the water at the curb. Then replace the valve.
If that is what you are asking?
Ron The Plumber 08-31-2006 06:21 AM
Beat you to the draw redline :)
redline 08-31-2006 07:24 AM
:notworthy:
