Leaking Water Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2011, 06:41 PM   #1
Leaking water connection
Hi there,
Earlier on this forum I asked how to connect two water connectors for a faucet and learned a close nipple would be best. At the hardware store I could only track down black steel. I installed and though it works fairly well, I was getting a very slight leak from all connections. So I threaded all with plumbing tape, which helped more but still slight leak, so then also applied some Rectorseal epoxy putty. Again, I am getting the slightest of leaks. Any idea how to resolve this? I screwed the connections with all the elbow grease I had and the help of two wrenches. I'm out of ideas. Is black steel a bad choice?
pisbouts is offline   Reply With Quote
Old 11-16-2011, 08:33 PM   #2
Rewards Points: 582
need a picture of what you are doing.....black steel on a faucet.....someone told you wrong.......
Old 11-16-2011, 11:05 PM   #3
I can't take a decent pic right now since they're wrapped in tape to stop the leaking. But basically they're 2 steel threaded water connectors with 1/2" FIP screwed to each side of a black steel nipple
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water leaking in through door on main floor down to basement. DIYinTraining Building & Construction 15 12-14-2011 07:24 PM
Water Leaking into Garage ghostee Building & Construction 2 06-11-2011 08:20 AM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
