Leaking Water On Ceilings And Walls - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2009, 02:21 PM   #1
Post
leaking water on ceilings and walls
The water has been leaking on to my ceiling and now on to the side walls of my room from the bathroom piping in the apartment above mine. I talked to the owners of the apartment above mine and they even changed their piping connections so that even if it were to leak it wouldn't reach my walls. But the problem still persists. I searched for the solutions and this link http://www.fixr.com/n.local-plumber.northampton.ma.html with almost the same problem. I will be really helpful if someone has the solution
zack1 is offline   Reply With Quote
Old 04-24-2009, 03:22 PM   #2
Rewards Points: 508
This problem could be the result of any number of problems. Have you removed the drywall from your ceiling to identify the source of the leak? A failed shower pan or toilet seal could be causing the problem. Is the flow of water steady, or does it seem to coincide with activity in the bathroom, e.g., a toilet flush or the use of the shower?
benjamincall is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Applying texture on smooth cement interior walls Flt_Simulation Remodeling 8 05-14-2009 06:23 PM
Ceilings and walls??? Tdoggy187 Carpentry 22 02-29-2008 11:07 AM
Clicking inside walls after use of water Jax newbie Plumbing 4 02-23-2008 01:48 AM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
