Old 12-05-2008, 11:10 AM   #1
Leaking waste pipe
I have water running down the wall where the waste pipe leading outside meets the wall. At first I thought it was ground water coming in but I've been noticed that after using the shower and bathroom there's seems to be more water (and there's no odor to the water). How would someone find out where the leak is in the pipe. Would the house's wall need to be broken and the ground dug up outside?
RichardP1234 is offline   Reply With Quote
Old 12-05-2008, 11:18 AM   #2
Leaking waste pipe
I have the exact same problem. Please email me at gordchevy@hotmail.com if you come accross any solutions that seem right.
Warm Regards,
Gordon
gordchevy is offline   Reply With Quote
Old 12-05-2008, 12:32 PM   #3
Leaking waste pipe
A couple reasons this could be happening. If the house settles, the line could be cracking. If the pipe is rubbing against the concrete it could have worn a hole in it. Wearing a hole is more common with PVC drains. I would think that digging outside would be easier, as a first step, to see where the water is coming from.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-05-2008, 10:08 PM   #4
Leaking waste pipe
Thank you, I will consider your advice. By the way, my waste pipe is cast iron.
Toilet Bowl to Horizontal Waste pipe BOBC Plumbing 3 08-30-2008 02:17 PM
Leaking waste pipe Ailish Plumbing 2 08-06-2008 10:19 AM
Toilet waste pipe leaking Louise2910 Plumbing 2 06-27-2008 09:48 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
Leaking waste pipe guvlin444 Plumbing 5 09-30-2006 02:36 PM
