Leaking Washing Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2012, 11:00 AM   #1
leaking washing machine
I have a maytag washer that just started to leak during the spin cycle. Is there a fix for this?
Shawn08 is offline   Reply With Quote
Old 04-22-2012, 11:07 AM   #2
where is it leaking? from the hose? from the bottom? From the top? On the Floor?
mcfarton is offline   Reply With Quote
Old 04-22-2012, 11:15 AM   #3
from the bottom front
Old 04-22-2012, 12:50 PM   #4
Rewards Points: 2,516
Yes there is. First find out exactly from what part of the machine the leak is originating from and "bottom front" is not the exact part.
hammerlane is offline   Reply With Quote
Old 04-22-2012, 03:18 PM   #5
Homerepairguy's Avatar
Rewards Points: 998
Front or top loading?
We had a top loading maytag washer and if I recall correctly, the washer had two screws on the sides that held the front panel on. Remove the two screws and the front panel can be pulled forward and then off, providing access to the internal parts.
If your washer works like this, you can then try to see what's leaking.
HRG
Homerepairguy is offline   Reply With Quote
Leaking Oatey washing Machine Shutoff Valve hammerlane Plumbing 25 04-03-2015 08:17 AM
washing machine hoses are leaking. tahmey@sbcgloba Plumbing 4 06-29-2011 07:51 PM
Leaking washing machine amyevans General DIY Discussions 9 05-26-2011 08:19 AM
Washing machine leaking sreed73 Plumbing 1 05-17-2011 06:51 PM
washing machine supply valve leaking tina2435 Plumbing 9 01-24-2009 04:17 PM
