#1 |
leaking vent stack joint
I have perused this forum on many occasions, but this is my first post. Anyone have any idea why a joint in a vent stack in the attic might leak? The house is only 7 years old. The vent stack is PVC. The leak occurs at a 90 degree joint. From there the vent runs almost horizontal for about 15 feet then joins with another stack and up and out of the house. The leak is definitely coming from the joint and is relatively slow as first noticed a problem on the ceiling in my garage where I found mold growing. I took a section of the ceiling out to find more mold. I traced the problem to the leak in the attic. Thanks
#2 |
Journeyman Plumber
It happens, probably from rain water, just fix it.
Fix it right the first time, so you won't have to fix it a 2nd time. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Can I just put sealer around the joint?
#4 |
Journeyman Plumber
You can try to add glue to the joint, might work, you won't know till the next rain.
#5 |
those fittings slip inside the 90 just wipe the joint 360 around good and run some pvc glue around it,,mystery how the water is getting up the insert of the 90?
#6 |
I can get it to leak just by shaking it a little, think there is standing water in it?
#7 |
thanks for the help. I'm gonna get back up there tomorrow and try to seal it up
#8 |
Are you certain its not a little less than horizontal? Wondering if enough water has built up in that pipe from rain/snow, then it gets heavy and pushes down harder on the far end of that 15', now its full of water? Can you get to the joint where it goes from horizontal to vertical through the roof? Try picking that up a bit and see if you hear/feel any drainage. If it is sagging just put a brace underneath it so there is always a slope.
#9 |
I'm heading up there now, I'll look at that as well, thanks
#10 |
any luck as to a solution?
#11 |
I got up there and put some epoxy around the joint. the horizontal pipe slopes down from the vertical towards the problem angle. As of just now when I checked, all seemed to be dry, and the mold clearing up. The pipe doesn't seem to have any water in it, which adds to the confusion as to why it leaks.
| Display Modes | |
| Leaking gable vent | jbinkley | Roofing/Siding | 6 | 02-05-2010 08:19 AM |
| Vent stack for kitchen sink | stan 41943 | Plumbing | 19 | 03-16-2008 06:50 PM |
| Stack Vent | A.Pierce | Roofing/Siding | 1 | 02-05-2008 03:11 PM |
| Corrosion problem in vent stack. | sgbotsford | HVAC | 2 | 12-01-2007 03:47 PM |
| PVC drain pipe leaking at joint, 2 part epoxy last? | harleysilo | Plumbing | 3 | 09-26-2006 01:29 PM |
