Leaking Vent Pipe In Attic - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2012, 04:36 PM   #1
Rewards Points: 109
Leaking vent pipe in attic
I received a text from my wife today informing me there was water on the ceiling in our laundry room.. I went home to find the vent pipe was not glued. I glued the pipe and have fan in the attic and the laundry room drying everything out. Is there anything else I should do?
Leaking vent pipe in attic-img_0446.jpg   Leaking vent pipe in attic-img_0447.jpg   Leaking vent pipe in attic-img_0448.jpg   Leaking vent pipe in attic-img_0449.jpg   Leaking vent pipe in attic-img_0450.jpg
mchipser is offline   Reply With Quote
Old 12-11-2012, 12:40 AM   #2
did u find the source of the water ???
hvac dude is offline   Reply With Quote
Old 12-11-2012, 05:34 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Are you sure th leak was from the un-glued joint The only water in there would be rain water coming down the pipe. The more common cause of water leaks in that area is a deteriorated gasket on the vent boot on the roof.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Thurman (12-12-2012)
Old 12-11-2012, 10:54 AM   #4
soil stack vent boot x2
paintdrying is offline   Reply With Quote
Old 12-11-2012, 11:59 AM   #5
Roofmaster
Rewards Points: 2,172
Glue
Did you glue the bottom of the EL to the horizontal run? I don't see any primer on the pipe. If you did, spray the wet spot on the ceiling with a little bleach/water and forget it, it will dry out. You cant see light around the pipe when you look up at the vent where it goes through the All-Vent in the roof can you? Is the vertical pipe supported at the rafter above?
Old 12-18-2012, 03:52 PM   #6
Rewards Points: 109
Sorry for the late response.
Ok I glued the pipe and let fans dry everything out over night.. I then sprayed water + bleach on the attic part and the area in the laundry room.. Thanks for the help!
EDIT: I forgot to add.. When I touched the pipe the pipe was not wet at all, only around the bottom where it wasn't glued. I can't see any day light between the roof and the
vent pipe.
Old 12-18-2012, 04:51 PM   #7
Roofmaster
You may need to put Kilz on any stains and re paint. Did you check for slope back to vertical branch and secure that pipe so it dosen't work its way down? If its in the middle between two trusses, just cut a piece of 2x 28 inches or so, nail it to the bottom of the top chord, so that it spans the trusses and buts the pipe. You can use a breeze clamp to hold it from moving, or even several turns the indomitable Duct Tape.
Best way to vent garage and attic mikeinaz Roofing/Siding 8 03-22-2012 10:48 AM
Vent pipe is leaking in attic OhmZoned Plumbing 30 01-13-2012 11:32 PM
sewer vent pipe Q! obsidian231 Plumbing 0 07-06-2011 12:08 PM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
