Leaking Valve Under The Kitchen Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2011, 08:41 PM   #1
cowboy dan's Avatar
leaking valve under the kitchen sink?
i'm no pro, but i can see the future.... it's rather wet. i cant change the valve without shutting the main off. i had my son take a pic cause it's a tight space at the moment. but i don't even want to touch the valve there either!
leaking valve under the kitchen sink?-001.jpg   leaking valve under the kitchen sink?-002.jpg
cowboy dan is offline   Reply With Quote
Old 04-01-2011, 09:22 PM   #2
cowboy dan's Avatar
i checked to see if i could turn the water heater off since it's only the hot valve under the sink that is leaking. but there is a bunch of plumber goop in the threads from some sort of previous fix preventing me turning the valve without breaking the blue handle. the tank is old anyway. all i need is to turn the water to the hot off.
leaking valve under the kitchen sink?-water-leaks-001.jpg   leaking valve under the kitchen sink?-water-leaks-002.jpg   leaking valve under the kitchen sink?-water-leaks-003.jpg
Old 04-01-2011, 09:39 PM   #3
Rewards Points: 1,088
Looks like your valve is missing the packing nut.
handy man88 is offline   Reply With Quote
Old 04-01-2011, 09:51 PM   #4
cowboy dan's Avatar
what is it? my cold looks the same... on the tap for the outside
Old 04-01-2011, 10:02 PM   #5
Looks like your red valve is missing the packing nut.
Old 04-01-2011, 10:07 PM   #6
It's the nut that tightens the valve stem seal.
http://www.google.com/imgres?imgurl=...:0&tx=78&ty=69
The Following User Says Thank You to handy man88 For This Useful Post:
cowboy dan (04-01-2011)
Old 04-01-2011, 11:13 PM   #7
cowboy dan's Avatar
cool. didn't know that. if it turn off the valve for the water heater, can i replace the hot valve under the sink? i'm hoping i can cause i do NOT want to turn off the cruddy main...lol
Old 04-01-2011, 11:18 PM   #8
Yes, that should work.
Just make sure you open a hot water faucet (preferably in the basement, if possible) to drain the water lines first.
You should though, probably consider hiring a plumber to fix the main valve, as you never know when you may need to shut it off and you won't have the hot water option.
Old 04-02-2011, 07:05 PM   #9
cowboy dan's Avatar
yea, i just hope the blue handle doesn't break. thanks again
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
What size for kitchen sink? oguevarra Kitchen & Bath Remodeling 1 01-19-2010 12:59 AM
New kitchen strainer leaking on Kohlr Cast-Iron sink wysiwyg6000 Plumbing 2 01-04-2010 09:47 PM
No hot water at kitchen sink allwet Plumbing 9 12-02-2009 08:37 AM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
