Old 06-13-2004, 01:19 PM   #1
leaking under sink when dishwasher on
My pipes leak when dishwasher on or lots of water goes down sink. Have Gooped up where pvc pipes connect but water still flows out. Do I need to put more goop or does un goop so the line can breathe?
Big B is offline   Reply With Quote
Old 06-07-2006, 07:07 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
At what point is it leaking, this info will help when asking a question.
Ron The Plumber is offline   Reply With Quote
Old 06-07-2006, 07:36 PM   #3
Have you tried to tighten the fittings?
There should be fittings on the P-trap and they may have come lose.
Are the fittings plastic or metal?
Have you removed the P-trap to see if there is anything lodged in it to caause a blockage?
redline is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 01:23 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
pedestal sink drain leaking sully Plumbing 2 02-05-2007 09:01 AM
